Old 04-04-2006, 01:26 PM
steve longo steve longo is offline
99 windstar
Maybe someone could help me.I need the little clips that hold the linkage rod for the IMRC . Also is there a diagram the illustrates what this whole system looks like inside? I am getting lean codes on both banks. I bought a new pcm to try and see if this helps but I don't know where it is located in the van
Old 04-04-2006, 01:52 PM
12Ounce 12Ounce is offline
Re: 99 windstar
What caused you to buy a PCM? I understand that it is a rather large task to replace a PCM ... not "physically", its held in place by only two screws under the cowling on the RH side engine firewall ... but "control wise", I think it must be "married" to the key transponder and the instrument cluster ( this requires equipment only a dealer is likely to have.).
A PCM is rather robust ... I have never known one to fail.
Your other question was about the IMRC links. I think they only come attached to the controller/actuator ... about $150. Or a trip to the junkyard.
