Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 04-04-2006, 01:01 PM
eraseraj's Avatar
eraseraj eraseraj is offline
Send a message via AIM to eraseraj
Question Bad idle once again
1994 Jeep Grand LTD. 4.0L
I have replaced the IAC, Spark plugs, Fuel Pump, Fuel Filter, and Cleaned injectors but still my jeep idles rough but never stalls. Bad idle only happens then the jeep is in gear
Please Help
Old 04-04-2006, 02:42 PM
legalfee legalfee is offline
Re: Bad idle once again
Have you tried replacing the ignition coil or PCV valve?
1984 AMC Wagoneer Limited (RIP - Burned)
1996 Chrysler Grand Cherokee Limited (for sale)
1999 Chrysler Sebring Convertible JXi
2004 BMW X3
Old 04-05-2006, 08:57 AM
teemsta teemsta is offline
I went throught the same thing. replaced iac,tps,maps, and it ended up being the coil. try replaceing that. mine was idleing rough and hesitating when I floored it. It was driving me nuts. after spending $$ on all of the above it ended up being a $30 coil. go figure
Old 04-05-2006, 11:55 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Doesn't the '94 have a cap and rotor? I'd replace those, as well as the spark plugs.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 04-05-2006, 12:52 PM
eraseraj's Avatar
Thumbs up Re: Bad idle once again
Thank you
I am going to get the coil fixed today
the 1994 jeep will live on
Old 04-11-2006, 11:23 AM
hoofan hoofan is offline
Was your coil the problem???
Also, (for anyone else out there) is there a good way to measure and see if a coil is just intermittent? I've done quite a few things to my 1996 JGC and I have a rough idle, hesitation and misfires (last recorded as 2, 5 and 6 but they bounce all over and I doubt it is mecahnical at this point) when I floor it as well.
The kicker is when I put a new IAC on it, it REALLY got low RPM in gear and stopped. I put the old IAC back in and it still idles rough, but better than the new one. Could the stalling with the new IAC be emphasizing the bad coil or pointing to a defective new IAC part?
So, should I take a stab at replacing or measuring the coil again. What brand of coil should I use. Does it have to be MOPAR or can someone recommend somethng else?
I have always suspected that I got a bad CPS, because it was the first thing that went bad, but I'm willing to look hard at the easy stuff first.
All other obvious "tune up" things have been done.
Thank you.
Bryan
Old 04-11-2006, 12:48 PM
eraseraj's Avatar
Wink Re: Bad idle once again
well i had some free time so i changed the coil, jeep is now running smooth
-thank god for Antomotive Forums
