Old 04-04-2006, 12:39 PM
91hatchgsr 91hatchgsr is offline
need help please!
i have a 95 gsr swap with ys1 tranny in 91 civic hatch
clucth grinding real bad apon engagement but not on way out
i can shift all gears with out clutch while car is running
any one know whay this is happening
also how install crx gauge cluster in dx hatch
most plug and play this does not but i have alot of the wiring from old crx
can i wire this gauge cluster to work in my hatch?
scott
Old 04-04-2006, 02:05 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: need help please!
Guage clusters have to be 88-89 or 90-91 to plug right up.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 04-04-2006, 05:22 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
If your tranny grinds when you apply the clutch, you've got a bad throw out bearing. If it grinds every time you put it in gear with or without the clutch, your syncros are toast.
Old 04-04-2006, 07:38 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
^^^or the diff is toast
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 04-04-2006, 10:10 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Not if he can shift without the clutch... That requires some precision inside the trans...not outside, if the diff were toast hed be having ALOT worse problems, liek not moving at all!
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
