Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 04-04-2006, 11:16 AM
rimfire,22 rimfire,22 is offline
valve adjustment
Hello to all,
I have an 89' Toyota Camary and was wondering if and how many miles do I drive before the valves need adjustment if any. I had thought it was every 30K BUT I was told my 4 cylinder doesn't need adjustment. Is this right?
rimfire,22
Old 04-04-2006, 12:39 PM
Daniel M. Dreifus Daniel M. Dreifus is offline
AF -Advisor
Re: valve adjustment
Originally Posted by rimfire,22
Hello to all,
rimfire,22
Check the clearances first.
They usually do not require adjustment - especially if the oil has been changed regularly.
To adjust you need to replace shims after checking with a micrometer to compensate accordingly.
Old 04-04-2006, 01:05 PM
Dan,
Thanks again dude! My oil is changed on schedule everytime. I'm gonna go back to using Mobil 1. :-)
rimfire,22
Old 04-04-2006, 01:34 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
IMO, if you haven't done head work that would affect the valve clearances, or you don't hear them, don't worry about adjusting the valve clearances.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 04-05-2006, 02:13 PM
typesix typesix is offline
My old 4cyl 89 Camry ran 223K miles without valve adjustments.
Old 04-05-2006, 02:28 PM
typesix,
Thank you for your posting. I'll rest a little easier. besides it's suppose to be part of the biggie service anyway. I have the same year and motor as you do.
rimfire,22
