Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 04-04-2006, 09:46 AM
danfman danfman is offline
Question brake caliper mounting bolts
I've had my Saturn about a year and haven't had to do any work on it, I guess that is a good thing. I was trying to change the brake pads last night but the caliper mounting bolts wouldn't budge. I've never seen bolts on that tight. I am assuming there is probably loc-tite or similar on them since they've never been removed before. I've worked on brakes before but have never seen anything like this. It looks like too tight of a spot to get a torque wrench back there. right now it's soaking in PB Blaster, but I have rarely had success with that. Anyone seen anything like this or have any suggestions?
Old 04-04-2006, 10:22 AM
drew300 drew300 is offline
Re: brake caliper mounting bolts
I changed my SW1 pads over the winter holidays. I didn't have a problem, but I remember them being tight. I did them cold, after sitting a night. I may have had to put a long "breaker bar" type wrench on them. You know, one of those 2' long arms for the socket. Another tip I heard is to just break them loose by tightening a notch, then back them out.
Also, MAKE SURE you pump up the fluid to the slaves again. I thought I had, but had an unpleasant surprise on the 1st drive.
good luck
Old 04-04-2006, 10:53 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
torque wrenches are used for seting finial torque after tightening, not for breaking loose sezied bolt. doing such will damage the wench and throw off calibation.
i suggest the following
1. breaker bar
2. breaker bar with cheater bar
3. heat(propane)
4. air tools
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Old 04-05-2006, 03:04 PM
Paddy Whacker Paddy Whacker is offline
I had the same problem on my '98 SL. The caliper bolt rusted, and froze itself inside the caliper. My neighbor used an impact gun to free it.
Good luck.
