Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 04-04-2006, 08:10 AM
murphy2 murphy2 is offline
wont start w/o remote
2000 explorer will not start unless keyless remote is used, which has a loud annoying chirp
how can I fix this?
Old 04-04-2006, 08:18 PM
bumpinkicker04 bumpinkicker04 is offline
Re: wont start w/o remote
how can I fix this?
I am not sure I understand. Do you have remote start? Or are you saying you can't unlock your door with a key, only the keyless entry?
Old 04-05-2006, 06:51 AM
do not have remote start, remote door locks. engine will not start unless remote for door lock is used, acc switch will work-radio, windows ect but the engine will not turn over unless the remote for door locks is engaged?
Old 04-05-2006, 08:26 PM
Is it an aftermarket keyless entry? Some of them come with a basic kind of starter disable that will not allow the vehicle to start unless the remote is used to unlock the doors.
Old 04-06-2006, 07:13 AM
it is a factory installed remote for door locks, it used to work fine and I never used the remote (do not like the loud churp) my wife used the remote to lock the doors,
a few months ago it would not start & a local mechanic sugested trying the remote and then start and that worked. When you stop enging it will restart within about 3 or 4 min. without using the remote.
thanks
Old 04-06-2006, 08:23 PM
thanks
I don't know. If it is a stock keyless entry there should be a way to disable the chirp so atleast you won't have to put up with that. The only thing is most stock keyless entry systems use a short beep of the horn not a chirp. A chirp is a popular characteristic of aftermarket alarms. Sorry I couldn't help you.
Old 06-25-2006, 12:18 AM
lgranger lgranger is offline
I had this exact same problem and took my car to a FORD dealership. Apparently there is a button below your steering wheel (near the hood release) that controls the mode of your alarm. If you have it in "valet" mode, you will need the remote to start the engine. However, if that mode is turned off your car should start just fine, without the remote. Play with the button, see what works. I hope this helps. I know the problem, and it was annoying!
Old 07-02-2006, 09:42 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
If that's the case you have the Ford ad on keyless entry unit from CodeAlarm. It's not an OEM part.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
