Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 04-03-2006, 11:52 PM
graygoose graygoose is offline
How do I make my car louder..removeing resonators..help plz..thanks
Someone told me if I remove some thing that muffle the cars sound. it will make my car louder ,how and where do I disconnect the resonators..Thanks
Old 04-03-2006, 11:56 PM
alphalanos alphalanos is offline
Re: How do I make my car louder..removeing resonators..help plz..thanks
probably the resonator that is connected to your intake system. Look at your airbox (it has the air filter in it) and disconnect any pipes that are attatched to it. Obviously dont disconnect your intake tube or your engine will be breathing unfiltered air.
96 EJ6. Future home of boosted B18C1.
Old 04-04-2006, 12:12 AM
oh I don't recall any other tubes or anything being connected to the airbox
Old 04-04-2006, 06:10 PM
trapped trapped is offline
Red face Re: How do I make my car louder..removeing resonators..help plz..thanks
This isn't really going to simplify things, but I should point out that while there is a true 'resonator', a resonating chamber, attached to the lower side of the air intake pipe between the air cleaner and throttle-body, there are also 1 or 2 muffling pieces of colored plastic (red, grey?) in the air cleaner itself that provide more airflow when removed... That is a common mod for Riviera hot-rodders and it does allow more intake and blower noise out of the left front.
Also, the traditional automotive use of 'resonators' refers to the last items in the exhaust system, although the GM manual for these cars refers to the single muffler behind the cat as the resonator, and the dual resonaters as mufflers... Aaughhh!
I've contemplated experimenting with straight-pipes in the exhaust system, but most of these joints are welded.
Old 04-04-2006, 07:21 PM
so which ones should I disconnect? or is there anything I could disconnect for more horsepower
Old 04-04-2006, 08:31 PM
lukedogg's Avatar
lukedogg lukedogg is offline
I gave you a tutorial on how to gut the airbox which will make the the blower whine much louder. The resonator in the exhaust is under the car right behing the cat. Your exhaust might get a little louder by removing that, but if you really want it to be loud, you should get a custom cat back exhaust made. Get flowmasters for loudness. I personally prefer borla, they arent as loud, but have a much nicer sound.
1976 Chrysler Cordoba. 6.6 Liter- Lowrider
1997 Buick Riviera 3.8 L Supercharged- Cruiser
Old 04-04-2006, 10:00 PM
Ok thanks what the does the resonator look like?
Old 04-05-2006, 01:26 PM
lukedogg's Avatar
a muffler. it is right behind the catylitic (sp) converter. There are two mufflers behind the rear wheels. the resonator is between the cat and the mufflers.
But is much closer to the cat, like less than a foot away.
Old 04-05-2006, 03:15 PM
Ok, so I can jack my car up and then remove it pretty easy?
Old 04-05-2006, 09:30 PM
sprucegoose's Avatar
sprucegoose sprucegoose is offline
Talking Re: How do I make my car louder..removeing resonators..help plz..thanks
No, not exactly easy easy... I am looking at doing this right now myself. It is welded in place from the factory. You can cut it off, but you'll want to make sure you leave enough pipe coming out of the cat to connect up another pipe up to. The inlet is like 2 1/2" and the outlet is 2 1/4", so you'll need an adapter at one end also.
I'm waiting for a day when I'm real bored, and I feel like laying under the car and getting rust in my eyes!
~Dave~
'08 Chevy HHR SS, Victory Red, 5 spd. 2.0L Turbo, 52K mi.
'98 Buick Riviera, Black, 3.8L Super-Charged, 228K mi.
'98 Chevy Tahoe LT, 5.7 Vortec, Black 241K mi.
'70 Pontiac Firebird Formula 400, 4spd 200k+ mi., in process restoration
'10 Dodge Grand Caravan SE, 11K mi.
Old 04-06-2006, 11:03 PM
96riviera18 96riviera18 is offline
im not trying to be patronizing but if you have a hard time finding the muffler v.s the cat, you should let someone with more automotive experience do your exhaust work.
Old 04-09-2006, 11:42 PM
84accord 84accord is offline
After reading this post I decided to finally un-cork the airbox and airway on my ’97 Riv.
I clipped the top of the staked posts holding the red liner in the lid. I used Alu-foil metal duct tape to cover/smooth the wart hole inside the rubber intake plenum. I also removed the Alu air straightener (honey comb) inside the intake manifold just before the mass air sensor.
I don’t have dyno results but the SC/intake noise is a lot louder. I’ve also got an Airhog filter (been there 4 months).
Rivrocket
Old 04-10-2006, 12:10 AM
be careful removing the MAF screen (honeycomb), it helps the sensor read the air volume and can cause you to run too rich/lean and your LTFT values will be off. i personaly got worse gas mileage, and less hp with the screen out due to LTFT locking in at wierd values durring WOT...every car is different but cleaning the throttle plate and polishing the throttle body will give you better gains and better mileage vs removing the MAF screen.
Old 04-11-2006, 11:44 PM
Thanks for the info. I'll take the car for a voluntary emissions test and see what it reads with the screen out. I've taken them out of several of my cars with no ill effects (so far).
