Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 04-03-2006, 10:22 PM
slickroper slickroper is offline
Send a message via AIM to slickroper
Question Manual Transission issues?
Hey guys, I just posted a couple weeks ago explaining bad gas like symptoms maybe related to a bad O2 sensor. I think the sytems I have are not related at all though. I'm leaning towards a worn clutch plate and pressure plate. Have any of you experienced this problem in an aged (1995 GXE w/ 158,000) max. I would love to get your input on what symtoms I should be looking for or if there is a way to diagnose without tearing the car apart.
Thanks for any help guys.
Old 04-04-2006, 01:32 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: Manual Transission issues?
Originally Posted by slickroper
... a worn clutch plate and pressure plate. ...
Thats about time when clutch is worn out, starts slipping. If you keep the car, dont ask twice but replace: tranny drop. Replace also axle rubber boots, tranny O-seals... Relatively cheap, normal wear issue; has to be done 'every 170k miles' on M/T vehicles.
Slipping -symptom: steady 50mph, last gear, push pedal...rpm rises with no effect on speed.
Old 04-04-2006, 02:43 PM
The rubber boots are done thanks. My max doesn't slip at 50 when I punch it. It is more so in first and second gear on acceleration. Is this maybe because the transmission is not bad enough, or is it maybe another problem like bad cylinder compression?
Old 04-05-2006, 01:21 AM
The clucth plate has still wearing surface left. On accel as wheels are not slipping you can see rpm rise according pedal push. If so, change clutch.
Old 04-05-2006, 08:22 PM
Thanks...I'm leaning towards that being the problem, I just want to make sure before I invest. Another suttle symptom I'm noticing is when I am in gear and have released the clutch, if I let up on the gas pedal and then push it again, it feels as though it grabs or jerks a bit. Does that fall in line with what we're talking about?
Old 04-05-2006, 10:41 PM
...just a little addition. When I switch gears I hear a little noise in the engine/trans area, like I can hear it switching gears. Could be an unrelated problem, but it's a fairly new noise to me.
Old 04-06-2006, 01:10 AM
With that mileage, changing clutch plate is standard preventive maintenance procedure. If u keep the car, just replace.
The other issue may be 'tired' engine mounts [6.], hard to diag online. Try push/pull with hands from the engine, should feel rather rigid. Compare to a new vehicle... Some DIY fill the mounts with urethane, some buy new.
http://www.cardomain.com/ride/748507/23
