Old 04-03-2006, 10:18 PM
Concept Tuning's Avatar
Concept Tuning Concept Tuning is offline
Hey Guys!
Hey guys what's up? I have a 91 Civic HB SI. I figured I would introduce myself and list what I've done so far.
97 D16Y8 block bored .020 over
97 D15Z6 Vtec head
SRP 10.5:1 c/r pistons
Eagle H beam rods
XTD Stage 2 clutch
Morosso Plug wires
DC 4-2-1 Header
OBD1 Swap with Chrome chipped P28 with datalogging capable
Short ram intake with "HKS" cone filter (even though HKS doesn't make cone filters )
Wicked Tuning Coilovers
17" Racing rims
Header back 2.5" exhaust
Future projects:
Fiberglass sub box enclosure
Turbo setup running low boost
Suspension setup
Problems I'm having:
Shfter doesn't feel right. Like it's hard to find the gears. (since new tranny and clutch)
Clutch makes sound. When you let off the clutch even in neautral it makes a whining noise.
Smokes a little on fresh build.
Valves make a loud ticking noise. I used Y8 valves in the D15Z6 head. Maybe it's that???
Well thanks for reading. Hope to contribute to the community.
Old 04-03-2006, 10:29 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: Hey Guys!
for one welcome aboard and if no one helps you here I use Honda-tech.com too thats my other forum i use alot....but for shifter its most likely the collar...like if you put it in gear does it have play in it? if so its the collar runs like 10 bucks at honda....valves dont matter those years are interchangable, did you use a feeler gauge to adjust them or maybe have a shop do it...sounds like they are to lose...another what kind of smoke is it???need more details...clutch i hear those problems all the time maybe the throw out bearing???
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 04-04-2006, 09:25 AM
Re: Hey Guys!
Well I just replaced the clutch, pressure plate, and throw out bearing. The smoke is a blue/gray kind of color. It's not coolant because coolant has that sweet smell. Plus there is no oil in the coolant.
I'm thinking maybe the rings havn't had time to seal good? Since the build it's only been ran about 2 hours.
Old 04-04-2006, 11:08 AM
Smoghog Smoghog is offline
Re: Hey Guys!
97 D15Z6 Vtec head
Eagle H beam rods
XTD Stage 2 clutch
Morosso Plug wires
DC 4-2-1 Header
17" Racing rims
Future projects:
Suspension setup
Tear down the shifter and regrease. If that is not it, and what made a difference for me was fresh oil in the tranny. Also check your shift linkage and shift support the bushing might need repl.
You believe the t-out is good. Might have got a bad one(It happens)
Rings not seated yet, I love the smell of fresh a build...
I would check them again.
Welcome... Sounds like you got a good set-up let us know how it runs after you break it in!
SH
Old 04-04-2006, 03:04 PM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
Re: Hey Guys!
welcome to the forum. i wish i could afford that good stuff
Old 04-04-2006, 07:36 PM
Re: Hey Guys!
I actually over paid for quite a bit
I was new and in a rush so I paid more than I had too. Oh well, I'm jobless and in college now so I have to search out the best deals. I waited 3 weeks just to get a O2 sensor $9 cheaper
