Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 04-03-2006, 09:42 PM
EricinTN EricinTN is offline
'01 4.7 V8 Exhaust leak
My Dakota has developed a slight exhaust leak. It is loud when the engine just starts, but goes away once it's hot. I tracked it down to the right side manifold gasket.
Anyone had to replace the exhaust gaskets? Is it going to be difficult or is it a straightforward job?
Old 04-04-2006, 10:48 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: '01 4.7 V8 Exhaust leak
The exhaust manifolds don't have gaskets.
My Mopars
Old 04-08-2006, 02:23 PM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Mopar#'s
53030812-Right
53030813-Left
Straight forward repair, soak the the bolts/nuts with penetrating lube on a cold engine a couple of hours before you try to remove.
NAPA lists this gasket set.
Item#: NGAMS16336
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Old 04-30-2006, 07:32 AM
Thanks for the info SteveO.
I don't do alot of repairs on this truck. It doesn't need much attention aside from oil changes, tires, and spark plugs. It's my work truck and I put about 45K miles on it every year. I now have 155K on it. Repairs since I bought it: throttle position sensor, clockspring, A/C fan resistor pack. I'm not counting brake pads and disks, those wear out on every vehicle. I love this truck.
Old 04-30-2006, 09:13 AM
sneakybert sneakybert is offline
Make sure you order new bolts . Chances are at least one is broken off . The good news is that the broken stud usually comes out of the cylinder head fairly easily with pliers or vise grips .
Old 05-07-2006, 08:07 PM
BleedDodge's Avatar
Why don't they come with gaskets from the factory? And you can buy them now?
That doesn't make any sense to me.
My Mopars
Old 05-08-2006, 09:33 AM
All 4.7 l engines come from the factory with exhaust manifold gaskets .
Old 05-09-2006, 12:16 PM
BleedDodge's Avatar
Right yeah, I thought this was a magnum engine for some reason. Thanks man.
It was in the topic title and everything, haha.
My Mopars
