Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 04-03-2006, 09:25 PM
plathegame plathegame is offline
93 trans sport code 34 problem
i have a 93 trans sport w/ a 3800 that i just got from a friend.. he has been driving it for the last 3 years w/ a code 34 maf circuit low code in it..
i have tried about 6 different maf sensors that i have in my garage and the code still comes back.. i checked the plug w/ a dvom and i have 4.3 v at the left contact and batt voltage across the other the other 2
i tried a known good ecm and still the code comes back
the air duct work is in good shape and tight and the air filter is clean
anyone have any ideas???
06 sierra denali 6.0 max
66 grand prix 389
00 caddy escalade 5.7
95 riviera supercharged 3800
85 park avenue 3.8
86 trans am 5.0 tpi
Old 04-04-2006, 07:16 AM
LMP's Avatar
LMP LMP is offline
Re: 93 trans sport code 34 problem
Given canari's experience, I'd check if all the wires that run from the MAF sensor to the ECM do carry current from one end to the other. THe MAF output as such is supposed to be a series of pulses, difficult to analyse using a DVOM. And measuring voltage at the maf socket with DVM at no load (maf disconnected) can show voltage even if it comes through a very high resistance path, but the voltage could then die out as soon as the maf is connected...that is why the tests below use a test lamp...
www.avigex.ca/xport/maftest1.jpg
www.avigex.ca/xport/maftest2.jpg
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 04-04-2006, 10:19 AM
thanks lmp, i 'll do the diag w/ the test light flow chart thurs on my day off and see wwhat happens..
66 grand prix 389
85 park avenue 3.8
86 trans am 5.0 tpi
