Old 04-03-2006, 04:37 PM
LilLaObOi50 LilLaObOi50 is offline
Send a message via AIM to LilLaObOi50
Clutch Problems
hey i own a 93 civic and when i push in the clutch pedal it dosent come back, im new in the automotive thing and i was wonderin what was wrong.
Old 04-09-2006, 03:18 AM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Re: Clutch Problems
Check for leaks, and air in the line. I know that when you have a good leak, the pedal "sticks" on the floor, and when you're bleeding the line which is basically making it leak but in a controlled manner.
To check for leaks, you need to look up on the firewall inside the car by where the pushrod goes through the firewall, and on the trans by the slave cylinder, (its alot eaiser if it is clean).
