Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 04-03-2006, 04:11 PM
bigred29067 bigred29067 is offline
k&n/throttle body spacer info
i heard that if i have a throttle body spacer on my tahoe that i cant use a k&n air intake? anybody else know anything about it? it wont cause any problems for a AEM brute force will it? thanks for the feedback
i have a 99LT with a 5.7L engine
Old 04-03-2006, 05:43 PM
777stickman 777stickman is offline
Re: k&n/throttle body spacer info
The spacer is going to "decrease" the distance from the TB to the filter box by however thick it is!! If you can get around that, go for it.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 04-18-2006, 10:58 AM
Jogit Jogit is offline
I've got an 02 5.3L/4WD with the Series 77 K&N system and and Airaide throttle body spacer and clutch fan...there is NOT enough room for the K&N intake hose to clear the fan shroud. The hose is smashed up against the shroud and clears the fan @ less than 1/4 inch. I'm removing it for 2 reasons... 1 - clearance, 2 - no notable performance increase with the K&N.
FIY - there is a thinner (~1/2" thick) throttle body spacer on the market that would allow the needed clearance if you still want to install one. Let me know and I'll look up the brand if you need.
Hope that helps!
Old 04-18-2006, 03:57 PM
dr olds dr olds is offline
you cannot run the k&n with a throttle body spacer, it will not line up or seat properly, i removed the spacer, did not notice a difference enough to keep it. also it whistles while driving, it got annoying after a while.
