| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
BAD SHIFTING...new clutch or tranny problem?
First off, I will not make this long and grammatically messed up...I know that is annoying.
Basically I have a 95 GSX manual with 105k. I put in a used ACT 2600 that had about 20,000 miles on it. Friend said the stock flywheel was in better condition than the clutchs flywheel so we just kept the stock one in there. 4 months pass. I am accellerating from a light..and in between first and second wihle the clutch is down...it SOUNDED like the pressure plates collapsed...and it grinded in gear and the clutch has been light ever since. (because of the stock parts left in there?) But ever since, the grinding has grown increasingly worse. It grinds a lot when the clutch is all the way down.. It NEVER goes into reverse without pressure and bad grinding..even when the car is off. Is this a tranny problem or a clutch problem??? (we threw in a new swap of synchromesh but it didn't do anything, that's why I figured it's the clutch)
1995 GSX M/t 87k[IMG][IMG] Gotta lotta work to do. [IMG] [/IMG]
Re: BAD SHIFTING...new clutch or tranny problem?
its your clutch, its not releasing all the way so you probably bent something or something like that
2004 Flame Red SRT-4 |Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd| Mods: ![]() |
So if I get a new clutch it will be fine??
Damn..I need to NOT drive my car until it gets fixed huh...
most likely, but I don't guarantee anything so you cant come back at me when I'm wrong
I donno... Mine started doing the same thing and at 105k it crankwalked after a 2600 for about 6 months...
I hope its not the same problem I ran into man...
-Brian
Why alot people got CW after they put in ACT 2600 or new clutch.
GM FOR LIFE !! NEW 1997 Camaro z28 6 speed illa never going back to import , but killa alway be nice to any DSM he saw ![]() looking for 2002 Trans Am LSX UPGRATE 2010 !! 97 Camaro Z28 95 camaro lt1 1992 Pontiac Firebird v6 auto -sold - Pony 1998 Mustang GT 4.6L Manual. Black 1995 Eagle Talon TSI AWD Turbo manual R.I.P 1994 Mitsubishi Eclipse Manual gray -Sold 1997 Mitsubishi Eclipse RS Auto White - Sold |
heavyer clutch= more pressure on the crankshaft=more bearing wear=
Is the crank still good after crankwalk or is it ruined?
-Brian
as long as there is no scoring/gouges/scratching then its fine
Sweet... I haven't taken it apart yet to find out. lol
-Brian
from what I understand if your motor crankwalks all it is is a main bearing that went out but it happens to be the thrust bearing so usually when it happens it takes as much shit out with it as possible.
Well, hopefully we caught it soon enough to save as much stuff as possible cause I'm sure somebody will need the good parts during a basic rebuild sometime...
-Brian
I highly doubt it is crankwalk...I mean..I realize that happens with the 2600..but I have travelled from Michigan to Georgia like 14 times since I put it in..could CW occur even after all that?? Should i put in a 2200 instead???
I just like burning all 4 tires
are u from georgia or michigan i live right at the hartwell georgia state line
![]() 96 GS - 5 Speed-Sold 1998 Ford F-150 XLT 4X4 |
![]() Just think, if it is CW then you can join the 2g 6 bolt group like I get to. lol
-Brian
