| Off-Topic Talk about anything other than cars. |
need some help
i just recently bought a 1997 gst off a family member who is in the marines and had no more use for the car at this present time. i was wondering if anyone could explain to me how to adjust the turbo down. it is running 14psi all the time and i would like to have to around 10 or 11?
Re: need some help
What do you mean "all the time?" Is it stock? Stock boost pressure is 10-15 psi for the 2g. I would leave it alone if I were you
. 14 is safe. Search this site for any futher questions of this nature, or go to www.vfaq.com.Edit: You should also post these kind of questions in the problem diagnosis sub-forum not the main forum.
![]() 96 GST 5 spd.......(R.I.P.) smashed by a fallen tree 2001 Camaro SS 6 speed goodness! |
Re: need some help
it has injen parts on it, and it has a manual i just dont know how to turn it up or down
Re: need some help
Why do you want to turn it down in the first place?
2004 Flame Red SRT-4 |Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd| Mods: ![]() |
Re: need some help
i just want to know how to turn it up and down.
Re: need some help
you can't run lower than the stock wastegate spring. if you want to go higher you'll need a boost controller, but you can't just turn up the boost without plenty of other mods first.
now - 2000 civic soon - 2002 is300
Re: need some help
it has a manual boost controller? i just dont know how to do it?
Re: need some help
I'm trying to help you out, but you're literally ignoring what we're saying. YOU CANT LOWER THE BOOST LOWER THAN THE STOCK SPRING WHICH IS AROUND 15 psi. To raise the boost, there is a screw on your boost controller, screw it down, it will raise the boost. DONT RAISE THE BOOST. Got it?
Re: need some help
-1997 Eclipse Spyder GST |Stock| -1990 Eclipse GSX |ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar| |
Re: need some help
Why exactly do you want to turn it down? Is it too fast? If it is give it to me and buy a Honda.You can get lower pressure springs cant you?
![]() Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order. The Purple People Eater will ride again... January 2011 can't come soon enough. |
Re: need some help
lol, that made me laugh newbs are one thing, but dumbasses that dont listen are another
