Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 04-03-2006, 02:45 PM
wgbtucson wgbtucson is offline
Idle air bypass valve modification
Just purchased 2000 P71 from local Sheriff. They added a small circuit to the idle air bypass valve. Only part of it was left on car when I got it. It was a wir spliced onto the white wire at the idle bypass valve. This wire went to a dash mounted on/off switch. The switch had a small 1/4 watt resistor in series with wire leading out of switch. The wire was cut there. Is this to increase idle to help cool engine more or to help give engine more power on high speeds? We get very hot summers here, 115 (Tucson Az) is not uncommon. Any ideas? I assume the resistor lead went to 12 volts??
Old 04-03-2006, 06:37 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
Re: Idle air bypass valve modification
never heard of this hope one of our fleet techs on here will get wind of this and help
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
