Old 04-03-2006, 02:17 PM
lotsofish lotsofish is offline
Rough idle.
What could cause poor idle on a 97 Grand Prix 3.8L/NA? I just replaced the intake manifold gaskets (both top and bottom.) The car sputters at idle speeds and up to about 1300 rpm. Sometimes it's hesitant on acceleration because of it. After it gets going, it is fine. Check engine light codes for cylinder misfire and lean fuel levels. I've checked a couple times and I did reconnect all sensors and vaccum lines correctly. I did replace the EGV gasket which looked like it may have been leaking and a vaccum line that had a split connector, but neither helped any. This problem started after I replaced the manifold gaskets.
Old 04-03-2006, 02:40 PM
jessep28's Avatar
jessep28 jessep28 is offline
Re: Rough idle.
When did you replace your plugs and wires last?
00' Pontiac Grand Prix GT
83,500 mi
Old 04-03-2006, 03:24 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Rough idle.
Did you get any codes for misfire and/or lean fuel, or did you check and didn't get any? You weren't very clear on that. Like JesseP28 asked, did you change the plugs and wires while it was apart, and if so, what brand did you use? Did you get the PCV valve in and use both o-rings, the large one at the top of the housing and the smaller black one that goes around the PCV valve itself?
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-03-2006, 04:38 PM
Re: Rough idle.
I didn't replace plugs or wires this time, but they aren't too old. The plugs are about 25,000 miles and the wires about 55,000 I think.
Yes, I did have codes for both misfires and lean fuel.
Actually, I did replace the PCV valve when I did this. I believe everything went back together right, but I'll check it out when I get home tonight.
Old 04-03-2006, 05:39 PM
richtazz's Avatar
Re: Rough idle.
was the code p0300 (random mis-fire) or p030X (x being the number of the specific cylinder missing, ex p0301 would be cyl 1, p0302 cyl 2, etc...).? If it's a spceific cylinder misfire, coupled with the lean mixture, would indicate a bad injector on that cylinder.
Old 04-04-2006, 10:06 AM
Re: Rough idle.
I read and reset the codes twice. The first time it was p0300 multiple misfires only. Second time was p0302 and lean fuel on cylinder 1.
I thought about the injector, but I thought that if there was a cylinder with a bad/clogged injector, it would get worse at a higher rpm. (Because the need for more fuel at a higher rpm.) Above 1300 rpms, the problem pretty much goes away. That and the fact that the second reading showed a misfire and lean fuel on different cylinders.
I haven't noticed a difference in gas milage.
I guess it's time to recheck what codes are set now. Plus I still gotta check the PCV valve to make sure the o-rings are in there right. I didn't get to that last night.
Thanks all for your help and ideas!
Old 04-04-2006, 12:32 PM
Re: Rough idle.
I ran over to Checker and borrowed their code reader during my lunch break.
The codes that came up are:
p0171 Lean Cyl 1
p0302 Misfire Cyl 2
p1406 EGR Valve Pindle Position
Before, the first time I scanned it and got a misfire multiple the second time only cyl 2, so I thought it was a fluke, like only cyl 2 was caught or something. Now only cyl 2 and the lean fuel on cyl 1 both come up again. Maybe I have multiple problems.
Any ideas? I don't know what the 1406 code means.
Old 04-04-2006, 12:43 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Rough idle.
p0171 Lean Cyl 1
p0302 Misfire Cyl 2
In the order of priority checkout the EGR code first. The EGR valve will cause misfire and a lean trim problem. It is a valid DTC error code indicating an electrical problem between the PCM and EGR valve. The PCM monitors EGR pintle position sensor to ensure the EGR valve is responding to commands from the PCM. The PCM is not seeing a proper feedback response. Voltage is less than .14 volts at all times or greater than .4 volts when EGR is commanded to zero or the closed position.
BTW - Several things can be checked such as the PCM 5 volt reference signal, etc.
Timeslip 08/12/06
AF Community Guidelines
Old 04-04-2006, 12:48 PM
richtazz's Avatar
Re: Rough idle.
I second what Bob said.
Old 04-04-2006, 01:46 PM
BNaylor's Avatar
Re: Rough idle.
Here are a couple of things to try that won't cost anything but a little time:
Remove EGR valve for cleaning:
Remove EGR electrical connector. Then remove two 13mm nuts holding it on the flange. Clean EGR spring loaded pintle with carb cleaner. Make sure pintle moves freely. Use WD40 spray. Also, if you remove EGR you may need a new gasket.
EGR Relearn Procedure (must have scanner):
With engine off, disconnect the electrical connector to EGR valve, take key to on, reset DTC error codes with scanner and immediately take the key to off position. Then re-connect electrical connector for EGR and take the key back to on.
Timeslip 08/12/06
Old 04-04-2006, 02:20 PM
Re: Rough idle.
Thanks, I'll try cleaning and lubing the EGV pintle tonight. Maybe it's just clogged or stuck.
How can I test the electrical part of it? Can I connect a volt meter to the connector to see what it is reading and what will that tell me?
Old 04-04-2006, 02:35 PM
BNaylor's Avatar
Re: Rough idle.
Yes but you will need a GP wiring diagram for pins to check. Try cleaning and the relearn first. If that doesn't work we can probably provide the info needed. A lot of us have service manuals.
Timeslip 08/12/06
Old 04-04-2006, 02:58 PM
Re: Rough idle.
I just though of another possibility, perhaps.
Bob, you said in another thread here from a few days ago called Service Engine Soon - Insufficient EGR flow that perhaps the EGR stovepipe in the upper intake manifold going bad could cause EGR codes.
I'm not exactly sure what the "stovepipe" is. Is it that thin tube in the UIM? There is a clip in the gasket that holds it in place.
Remember, I just had the intake manifold apart. About a month or so ago I replaced a leaky lower intake manifold gasket (that common problem.)
If that piece moved out of place when I was putting it back together, could this be causing my problems?
Old 04-04-2006, 03:41 PM
BNaylor's Avatar
Re: Rough idle.
On the P0401 that was related to the EGR flow test where the error pops up after a PCV valve job when the black o-ring is omitted. It causes loss of engine vacuum. Any loss of engine vacuum may affect the EGR valve as far as when the PCM tests it or calls it into service. It affects Manifold Absolute Pressure (MAP).
The stovepipe is that thin tube part on the left hand side of the UIM/LIM. You can see it when the throttle body is removed at the point where the throttle body hooks up to the UIM. The gasket sealing around it is important. I would say that if it did not mate up good the outcome would be some sort of internal vacuum leak so its possible.
However, the EGR code you are getting indicates the EGR is not functioning properly mainly electrically than indicating that there is an actual EGR flow problem.
Whatever your problem is I guess we can all agree that it has something to do with the UIM/LIM job.
Timeslip 08/12/06
Old 04-05-2006, 11:09 AM
Re: Rough idle.
Here's what I did last night...
Installed new black PCV oring.
Removed EGR, cleaned and lubed the pintle. It wasn't very dirty and the pintle already seemed to be moving ok.
Checked all plug wires and vacuum lines.
Unfortunately, I don't have easy access to a code reader, so I wasn't able to reset the EGR like you said to. I don't have the money to buy one right now, so whenever I need it, I have to borrow the one from Checker. I'm going to have more time this weekend to work on it, so I think I'll wait until then and borrow it for a couple days.
What I noticed... I had the engine running while I was down there inspecting some of the vacuum lines and stuff, and I heard what sounded like an air leak, but I couldn't find it. It sounded like it was coming from under the throttle body or under the egr; at least on that side of the engine. I felt around, but I couldn't feel any air. I think I'm going to have to take the throttle body off and look at that pipe that connects the egr to the manifold. (Is that the thing that's called the stovepipe?) Is that pressurized? Is there anything else down there I should look for? Both the lines that connect to the side of the throttle body are ok.
I was also wondering about something that's inside the UIM. It's a small plastic tube. There is a clip on the gasket that holds it in place. I think I got it back where is was, but what is it for? If I didn't put in back in place right, could that be the cause?
Thanks
