Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 04-03-2006, 01:58 PM
Bagi Bagi is offline
engine hesitation on acceleration
when I press on gas the engine hesitates as if it's going to stall and the acceleration takes effect only after 2 seconds or around there, don know why! any response appreciated. Ooh yeah the check engine light is also on.
Old 04-11-2006, 03:48 PM
dwilliams141 dwilliams141 is offline
Re: engine hesitation on acceleration
What year/model is your car?
Old 04-16-2006, 02:16 AM
i have a corolla 01', any idea is greatly apprecieated!
Old 04-19-2006, 08:25 AM
sounds like your intake is getting bogged down due to too much air or fuel. I'd probably get the computer checked out, because on newer model cars like yours, they can give you details on why the check engine light is coming on. I think some places like advanced auto parts will read your computer for free.
Old 04-19-2006, 10:38 AM
Patman525 Patman525 is offline
Also check your spark plugs and wires, if you have a misfire, that causes a decrease in response time and will feel like its bogging down.
Old 04-19-2006, 11:16 AM
johnholl johnholl is offline
TPS and MAF should also be checked
Old 05-08-2006, 11:54 AM
update on engine hesitation on acceleration
hey guys thx for info. I've checked the engine light by the scanner and it said: code "PO171. SYSTEM TOO LEAN. BANK 1". Somebody pls tell me what does it mean?
Old 05-17-2006, 12:24 PM
fastcorolla fastcorolla is offline
lol simple, car is runin to lean(bad mixture) do u have any mods? well in either care simple try reseting ur ECU...
1.unplug (-)cable on Bat. Let sit for 30 min
2.Plug back in, turn car on idle for 5min (with no accessorys)
3.Unplug (-)cable on Bat. for 30 seconds
4.Plug back in, go drive around how u normaly drive (fast, or slow).. Dont hit redline it cause's learning problems for the ECU..
This will give your ECU a chance to 'learn' how all the sensors act to your car during accell, cruse, idle...
also if u do it right u can set it to how u want it to drive..(faster)
Old 05-30-2006, 01:20 AM
chinozie chinozie is offline
what's the diff between disconnect -ve cable and the EFI fuse...???
guys...it seems that we are have the same problem that haven't found the solution yet...
see the link below...
http://forums.club4ag.com/topic.asp?TOPIC_ID=141009
Old 08-05-2006, 06:51 PM
astrosurfer astrosurfer is offline
has anyone checked the vacuum connection to the auto timing advance.
what about the throttle sensor and mass airflow unit perhaps?
just a suggestion
Old 09-21-2006, 01:04 PM
Ncgreasemonkey's Avatar
Ncgreasemonkey Ncgreasemonkey is offline
Sounds to me like you've got an intake leak somewhere. Take some carb cleaner and spray around the intake with it idling... when you notice an idle change *bingo* there's your leak. Also check vacuum hoses... I suspect it's not going to be to some sensor (such as map or timing advance, becuase it'd have a code for that too, presumably). If it's a MAF system (has the sensor right past the airbox, make sure the runner from your air box to the intake doesn't have any cracks or loose connections.
Old 09-29-2006, 03:48 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
is your, or does your idle speed seem abnormally higher/ That would be an indicator also of a vacuum leak.
Another possiblity is a bad O2 sensor. if you've neglected changing or cleaning plugs for a while, the carbon builds up in the exhaust, and the O2 sensor gets clogged up. Since it can't read the exhaust contents, the ECU guesses and says it's lean.
just of htought
Old 03-25-2007, 10:19 PM
jpg366 jpg366 is offline
My '97 had that kind of hesitation, was showing random misfires, and needed one of the ingnition coils replaced. Unfortunately, these OBD-II messages require some guesswork and experimenting with parts replacement.
Old 10-25-2013, 06:38 AM
dksjan5 dksjan5 is offline
My '06 had the same hesitation problem at red lights and stop signs, every time I hit the gas pedal fast.
I found the Air Intake hose clamp completely loose. This happened after the air filter was replaced.
