Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 07-11-2002, 08:40 AM
Super Spec V Super Spec V is offline
Boost Coversion
Does anyone know the conversion of MPa to psi?
Have aboost guage that reads a max of .15MPa. Tried it on the rex and it reads from .07 to .09...almost .1MPa.
Please advise
Thanks
A Game of chess is like a sword fight. You must think first before you move!
Old 07-11-2002, 09:27 AM
RE
I found it out......1MPa = 145.0377psi
Im wondering....this means that my car is only running 12 or 13 psi of boost..is this normal...do some of the rexs make more boost than others from factory?
Old 07-11-2002, 12:34 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Well a lot of cars that are turbocharged will boost around a certain level. Like mine for instance was rated between 12-14PSI, mine runs at 13.9 last time I checked.
Old 07-11-2002, 02:28 PM
RE
Im wondering if i should be concearnedit doesnt always hit the max boost...depends what gear..temp...ect...should i be concearned??
Old 07-11-2002, 03:09 PM
Polygon's Avatar
The Red Baron
Nope. Sometime you will hit max boost and sometimes you won't, nothing to worry about.
