How to repair passenger outside mirror - 1995 Buick LeSabre Custom
Hi!
I'm trying to replace the passenger side mirror on my '95 Lesabre. It appears as though the only way to do this is to completely remove the door panel. I'm not sure how to do this without breaking something. The instructions from AutoZone are less than useful as the door panel is a different design. I already have a replacement power mirror - just need to get the door panel off! Thanks! |
Re: How to repair passenger outside mirror - 1995 Buick LeSabre Custom
Hello
The door panel is held on with plastic button darts forced into holes and screws. Buy a tool that is made to pull these out. It's like a prybar with a slot in it so you can get the darts out of the hole. Any good auto parts store stocks them. Also, go to your liberary and check out a manual on your car. Some Libs also have a sub. to AlData that you can use. Regards Dan
******************************************* Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK Photos of my repairs: http://dansautopictures.shutterfly.com/ Check this out:http://threewheelmotorcyclemetro.shutterfly.co A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854 95 Windstar 240,000+ 98 Windstar 136,000+ 09-25-2008. 85 Dodge 1 Ton Snow mover gas hog 91 Mazda Protege free beater SW MN |
1) You will need the GM door panel removal tool as LeSabre97mint mentioned, a small standard screwdriver, a large phillips, a small ratchet, and a small Torx driver (star shaped tool, or an Allen wrench should work)
2) Remove the red light lense from the side of the door panel. Inside the opening is a small bolt (sorry, I don't recall the size!) holding the panel on the inner door frame. Remove this small bolt. 3) Using the star shaped Torx driver or Allen wrench, remove the power lock switch plate and disconnect the wire connector from it. 3) Using the small standard screwdriver, pry off the black power window switchplate (it's clip faces the front of the vehicle, don't try prying the back, as I learned from personal experience!) 4) Carefully disconnect the black switch plate from the power window wire harness with the small screw driver. 5) Underneath the switch plate opening, remove the 2 screws (or bolts). 6) Using the small screwdriver, pry the black inner door handle covers towards eachother to gain access to the 2 large phillips screws, then remove these and pull the handle out of the door panel. 7) Finally, remove the plasic door clips with the removal tool as LeSabre97mint mentioned. The panel should come right off. 8) If you want to completely move the panel out of your way, disconnect the courtesy lights from behind the panel. Good luck!
![]() http://www.cardomain.com/ride/2653398 1992 Buick Park Avenue (Daily driver) 2001 Saturn SL1 (gas saver)
