Old 04-03-2006, 10:53 AM
moscit moscit is offline
Question Decals over decals
Does anyone out there have experience with applying a decal over an already applied (and dry) decal.
After reading MPWR's decal replacement tips, I was insipred to create decals to replace the ones in my Tamiya F50 kit, which I do not like the color of. Only thing is, I had already applied a couple of them .
Now I want to cover them up with the new decals but don't know if I should try to remove the applied ones or just apply the new one over them.
Does anyone know how the decals will react if they are layered?
Any insight would be much appreciated.
Old 04-03-2006, 11:01 AM
CADguy's Avatar
CADguy CADguy is offline
Re: Decals over decals
Removing the existing decal is easy as putting scotch tape or masking tape on it and pulling it off. Unless you've covered it with clear.
Matt
Old 04-03-2006, 11:20 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
No worries. Decals over decals is not a problem- otherwise CF work like on my F50 would not be possible- they have to overlap somewhere. The only problem you may have is if the decals you've already applied are of a significantly different color than the rest of the area you're decaling- so if the new decals are a bit transparent, they may show through the old decaled and non decaled areas (make any sense?). Like CADguy said pull them up if you need to, or paint them over with another color for a new base color (gloss black is good for CF). For kevlar work (like on my F40) it's hard to come up with a background color close enough that it won't show a difference with overlapped decals (and SMS kevlar is kind of transparent)- so I'm putting a double layer of kevlar decals down. One for an even base color, one for a final finish. Time consuming, but it looks pretty good.
PHOTOBUCKET SUCKS
Old 04-05-2006, 07:28 PM
Thanks for the pointers guys.
I applied directly over given that the carbon decals I was using were not transparent at all. I worke rather well.
Gotta work on the template creation though, the custom replacement decal I made was a little off .
Hopefully it will be more precise when using the unapplied originals as templates with the photocopy method MPWR described.
Cheers.
Old 04-06-2006, 03:40 PM
MPWR's Avatar
So, let's see some pics and a progress thread!
PHOTOBUCKET SUCKS
Old 04-06-2006, 10:26 PM
I'll post some pics as soon as I've got a completed section, at this point most likely the cockpit.
As for the WIP thread, I'm a really slow builder so it would be excruciatingly long intervals between posts. Not sure that would be appreciated...
Thanks for the pointers and the interest.
Old 04-07-2006, 08:29 AM
MPWR's Avatar
As I'm sure people here would point out, it doesn't stop me!
Build at your own rate- but it's more fun when you share.
PHOTOBUCKET SUCKS
Old 04-07-2006, 10:04 PM
Well, MPWR you convinced me. My WIP thread has been started.
http://www.automotiveforums.com/vbul...41#post3974541
Let me know what you think.
The carbon on the center console is the one discussed here previously.
