Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 04-03-2006, 10:39 AM
dmg1969 dmg1969 is offline
Burned out shifter position light bulb
The other night I noticed that the light bulb which illuminates the automatic transmission position is burned out. How do I go about replacing that?
Thanks in advance!
Dave dmg1969)
Old 04-06-2006, 04:00 PM
tomcat_cool17 tomcat_cool17 is offline
Send a message via AIM to tomcat_cool17
Re: Burned out shifter position light bulb
It's not very fun, but it can be done. The bulb you can get at any automotive store or walmart, I forget the bulb number. You have to remove the back portion of the center console first (the emergency brake half) buy lifting the back end up. Undo the screws in the center and remove the shifter knob. Remove the exposed screws holding the front piece of the center console down and lift up, undo the clips by the dash. Be careful pulling on it because those clips are really fragile and it won't go back together snug if you break them. Once the console is removed, undo the screws at the base of the shifter bracket and turn on its side. Pull the wire harness from the clip holding it underneath the shifter and twist the bulb out. Obviously do the reverse for installation. Hope this helps. Let me know if you need more instruction and I will see what I can do.
Old 04-08-2006, 12:47 AM
AltecZX2 AltecZX2 is offline
Send a message via MSN to AltecZX2
you act like it hard...i pull that shit all the time its like 5min lol
FORMERLY: zx2srdotnet(1,380 posts)
2001 Esxort ZX2 - Traded
2000 Escort ZX2 S/R - Sold
2003 Mustang Mach1 - Totaled
2014 Altima 2.5 S - Purchasing Soon
Old 04-08-2006, 03:47 PM
It's alot easier on a manual tranny than it is an auto to remove that center console. You have to be very careful not to break any of the connectors, and on older ZX2 it will be very stubborn to remove without cracking the plastic up by the radio stack. Changing the light itself is easy, it's getting to it, especially if you have not done it before. There aren't any good pictures to show you how it comes off, so you just have to be careful how you pull and try to get the best looks at the connectors holding it together.
Old 04-08-2006, 03:54 PM
ive owned an auto...its not to much different.
Old 04-08-2006, 05:37 PM
How long did it take you the very first time Altec? Took me about 30 minutes. And that was going slow and making sure everything was coming apart the way it is supposed to. I was just makig sure he would allow him enough time in case he runs into a snag or isn't as confident about doing it as you are.
Old 04-13-2006, 10:16 PM
maybe 15-20
Old 04-14-2006, 10:24 AM
Originally Posted by AltecZX2
maybe 15-20
Exactly, so it will take him more than 5 minutes. Didn't want him to think he could do it automatically in 5 minutes and not allow himself enough time.
Old 05-17-2006, 06:26 PM
Mlevan78's Avatar
Mlevan78 Mlevan78 is offline
Question Re: Burned out shifter position light bulb
should there be a shifter position light in the center console for all models of zx2? I own a 98 which seems like a very base model, manual windows and locks. I have never seen a light come on in the center console since i bought it for the shifter. Just curious if anyone knows before i start pulling the console apart.
Old 05-17-2006, 07:57 PM
Yes, every Z should have a light underneath the letters of the shifter console. Mine is also a early date base ZX2.
Old 09-27-2006, 08:20 PM
mls60442's Avatar
mls60442 mls60442 is offline
I know this has been inactive for a few months and I'm new, but I just changed my bulb today on an '02 Z. It wasn't that hard, the second post was very informative. The bulb number I think was 158, at least that's what I think the bulb said. I put a 168 in and it works just fine.
Old 09-27-2006, 09:07 PM
Glad I could help out! How long did it take you, and did you break/crack anything?
Old 09-27-2006, 10:00 PM
mls60442's Avatar
It took me between 15 and 30 minutes to get apart. I want to say it was probably around 20 minutes or so. I didnt break or crack anything. The only thing that did crack was an outer ring to one of the black circular clips on the outside of the console beneath the radio, but I think it was already cracked before I started. I just worked slowly and made sure where each clip was. The hardest part was putting those outer black circular clips back in. But oh well, I finally have my shifter light. I haven't had it since I got the car used about two and a half years ago and I have to say I like it.
Old 09-28-2006, 06:18 AM
2.5 years? Yea, its gotta feel like a new interior!!! Yea, it bugged me when it went out on my ZX2, I think I only waited 2 weeks before I replaced it, missed having that glow below my eyes I guess.
