Go Back   Automotive Forums Car Chat > Buick > Riviera
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-03-2006, 08:45 AM
schustla schustla is offline
95 Riviera Fuel leak Please Help if you can
I have a 1995 Riviera V6 3.8 (supercharged) I also know very little about this so please bear with me in my explanation.
I noticed recently a fuel smell in the car. When I looked under the hood (with the engine running) there was a pinhole leak in one (the middle) of the three black hoses that connect the metal fuel lines into the engine. (The three hoses are located near the rear of the engine on the driver's side).
The hoses are labeled GM6264 ITT Automotive Not Repairable or replaceable.
My questions are:
What is the name of the hose (part) and can it be replaced/repaired? If it can be repaired how much should that cost?
The car runs and drives but I would imagine fuel leaking is a serious serious problem
Any help given will be greatly appreciated?
Old 04-07-2006, 01:16 PM
96riviera18 96riviera18 is offline
Re: 95 Riviera Fuel leak Please Help if you can
you can get new hoses from delarships and maybe napa. they are not too difficult to replace. i would not drive the car with a gas leak, no matter how small. the lines say not reparable b/c its not a good idea to duct tape a fuel line and hope it still works if it has a hole then it is probable dry rotteted and needs to be replaced.
Old 08-26-2008, 05:56 PM
sese sese is offline
i had the same prblem do not drive the car untill fixed.. i took my to a mechanic and they put the wrong size hose on it worked for a week or so then the leak came back. get the right size hose, ask the dealer if necessary. you do not need to change the whole line (metal part) like on mechaic told me. i have no leak now.
Old 08-26-2008, 08:05 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Welcome to AF.
Thanks for contributing. Your reply would probably be helpful if it was posted at least two years ago. Since this is an old thread it has been closed.
Old Thread Guidelines
Timeslip 08/12/06
AF Community Guidelines
Closed Thread
