Old 04-03-2006, 02:52 AM
TKUERZINGE TKUERZINGE is offline
Cleaning The Eacv.
How Do You Clean The Eacv? My Civic Has A Very Erratic Idle After Warm Up. Hoping This Will Help. Thanks.
Old 04-03-2006, 03:04 AM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: Cleaning The Eacv.
brake cleaner or fuel injector clean which i prefer
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 04-03-2006, 05:52 AM
Thanks For The Info. Tk
Old 04-03-2006, 12:52 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Yeah once you unbolt it your going to find two holes, one has a screen...clean that and blast both holes with cleaner generously, the drain and let it dry a little, compressed air helps alot, then blast it again and use the air again, give a good hour to dry completely before you put it back on...and hope it solves your problem!
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 04-07-2006, 12:59 PM
pokey69 pokey69 is offline
My idle does the exact same thing, only after it warms up, but, when the idle goes nuts, the engine light comes on. I'm wondering if this happens to all cars when the eacv gets plugged up?
Also, i'm wondering if somebody could tell me exactly where the eacv is located?
Thanks alot.
Keenan
Old 04-07-2006, 01:07 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
On mpfi cars, eacv is on backside of intake manifold. If your CEL is coming on, pull back passenger floor board carpet and count blinks then go to FAQ sticky and look up the code you have.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
