Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > General Discussion
General Discussion All general comments or enquiries go here. Website, club oriented, or general Skyline banter.
Old 04-03-2006, 01:29 AM
nissan89 nissan89 is offline
Question Please I Need Help!!!
I have a nissan 89 skyline sedan and it has a problem that noone can seem to work out. when i have been driving it for a while and it gets warm it will just die once the rev's get below 1 1/2 if you put your foot down it will just splutter and then stall. then it will not start again for a minute, it sounds like its flooding almost and is very fumey. then after a couple of minutes it will start again , drive fine for a little while then do it it again. it first happened about 6 months ago didint do it for 4 or 5 months and then has started doing it again. i have been told it could be my immobiliser?
Old 06-22-2006, 01:25 AM
Howey's Avatar
Howey Howey is offline
Re: Please I Need Help!!!
best place to ask this question would be http://forum.r31skylineclub.com they are very helpfull and know what there talkin about
Old 11-01-2006, 08:03 PM
GTSGOD GTSGOD is offline
check your gap on your spark plugs cause i had a similiar problem and i closed the gap to .75 mm. and run a colder spark plug as turbos run pretty hot
Old 11-17-2006, 07:55 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
It is a non turbo 89 (R31)Skyline so it would either be the crank angle sensor or air flow meter, which are common problems for these engines.
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
Old 01-13-2007, 12:53 AM
yasfir yasfir is offline
I got a Skyline R33 GTS-T I was driving from home and the turbo was fine. When returning home the turbo didn't kick in basicaly It was like driving a non turbo skyline. Would any1 know what the problem would be?
Old 01-13-2007, 06:53 PM
are you running the stock turbo? and have you boosted it?
Old 01-14-2007, 05:01 AM
mmcleo11's Avatar
yasfir: Check that you do not have a boost leak. Also check the turbo has not been over 12psi
N14 Pulsar
The workhorse...
Twin turbo 5.7L LS1
