Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-02-2006, 11:03 PM
robertjr's Avatar
robertjr robertjr is offline
91 Dodge ram350/Balljoint replacement?
Can anyone tell me what tools I will need to replace my worn ball joints, and how long it should take me, and any secrets that have been learned the hard way that I can avoid. Thank you:
Old 04-03-2006, 04:12 PM
PWMAN's Avatar
PWMAN PWMAN is offline
Re: 91 Dodge ram350/Balljoint replacement?
Just take it to monroe/meineke or some garage and have it done, trust me it's worth the money. Otherwise you'll need a torch and a press at the minimum and it will probably take all day.
88' Dodge Shadow- 2.2L, 5 speed...a couple mods
[email protected] MPH
Old 04-03-2006, 06:39 PM
HEMIDAZE's Avatar
HEMIDAZE HEMIDAZE is offline
Autozone has a free tool loaner program that includes a ball joint press if you really want to do it yourself.
Old 04-03-2006, 10:39 PM
sneakybert sneakybert is offline
Is your pickup two or four wheel drive.
Old 04-04-2006, 02:31 AM
robertjr's Avatar
Its 4wd.
Old 04-04-2006, 12:08 PM
2000mudder's Avatar
2000mudder 2000mudder is offline
lot of work!!! need ball joint press, hub nut socket, might as well replace bearings and seals while it's all apart. i spent $300 an parts and replaced all ball joints, u joints and all bearings and seals plus rotors. labor is prob close to $1000 for this job. you need to press out the upper ball joint to get to the lower one through the hole where the upper one was.then you need to press in the upper first for the same reason.
Old 04-05-2006, 09:08 PM
A 1991 W350 uses a tapered roller bearing for a lower ball joint . The upper one consists of a tapered plastic cone with a spring to preload it . Changing the upper plastic cone is relatively simple if the front end is not to rusty . The right side is just four bolts to remove the upper retainer . The left side is the same except you have to deal with the steering arm . The lower bearing almost never fails if greased . ( I have never changed one).
Old 04-08-2006, 01:27 AM
robertjr's Avatar
thanks guys, any other info or suggestion would be great.
Old 04-09-2006, 03:14 PM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Thumbs up Re: 91 Dodge ram350/Balljoint replacement?
You will find some more info here.....
http://autozone.com/servlet/UiBroker...3d800ffded.jsp
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
