Old 04-02-2006, 09:43 PM
Integra4200's Avatar
Integra4200 Integra4200 is offline
Send a message via AIM to Integra4200 Send a message via MSN to Integra4200 Send a message via Yahoo to Integra4200
help... sub cuts out
i got it hooked up and it works fine then the amp goes into pertection mode when i turn the gain up hardly at all. it doesnt even start to beat hard then just shuts down. why would it be doing this?
96 Jeep Grand Cherokee Laredo
5.2 L 135k miles.Flowmaster muffler/mangaflow cat
I wrecked it about a month ago. damage is the front end passenger side. i have 3 good 80% tread 30" wild countrys bought from les schwab. (4th one poped due to accident.)I also have brand new (still wraped in plasitc) front/rear bumper covers. the grey ones. also a brand new chrome grille.let me know if you need something. it will be going to the junk yard in a few weeks so hurry
Old 04-03-2006, 11:23 AM
BlasZ24 BlasZ24 is offline
Re: help... sub cuts out
Did you check for any shorts in your wiring yet?? Check the resistence of your subs, if this is within your amps operating range for resistance check that you have good ground. If all that looks good you may have a bad amp.
Good Luck!
Matt
Old 04-03-2006, 11:46 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Well considering that the PG Ti series subs are all single 4 ohm i highly doubt its a wiring issue. Good ground wouldnt make it go into protect unless its a non existent ground. Sounds like a wiring issue as far as the sub is concerned. Either this or the amp has a bad power connection. Check the sub wires for frayed ends at the amp or sub and check the power wire to make sure its not loose. Also what gauge wire are you running at least 4 gauge would be advisable. And last possibility the amp or sub could have a problem. Try another amp, or try another sub on the amp to see which it could be.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 04-04-2006, 10:34 PM
yea this isnt my setup i put my old kicker compvr in my friends car. i think the sub is just fried. when i hooked it up to my jeep it was doing the same thing just cutting out after i turned the gain up hardly at all. thanks for the help tho
