Old 04-02-2006, 07:45 PM
F-BRD_fan F-BRD_fan is offline
metallic knocking sound after start-up
i have this problem during start-up of the bird. sometimes the engine makes this sound like metal hitting metal. metallic knocking sound basically. when i tap the gas the tempo of the metallic knocking sounds rises. then after a minute or so it stops and the engine runs as normal..hoping you all might and idea of what could be the problem...also just want to thank you guys for the knowledge and good advice that is put out on AF, best forum on the net.
Old 04-02-2006, 09:47 PM
79Bandit's Avatar
79Bandit 79Bandit is offline
Re: metallic knocking sound after start-up
Sounds to me like piston slap...if it goes away after the engine is warmed up then thats probally it piston slap..dont worry then because its not doing any damage.
Old 04-03-2006, 05:04 PM
hey Bandit is there someway to prevent "it" from happening?..
Old 04-03-2006, 09:16 PM
79Bandit's Avatar
for an easy fix...im not sure maybe mr.lous would know the only thing i could tell you is to break her apart get to the pistons and see if theres a gap there...but i would not do that untill a proffesional had told me that it was piston slap...
http://www.pistonslap.com/
http://www.allpar.com/fix/chatter.html
those pages might give you a heads up to what your going against.
Old 04-03-2006, 10:01 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Year of car?
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 04-04-2006, 02:45 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
Google the term "piston slap" and you will get lots of info about it . LS1's are well known for it now . Alot of the new alluminum block engines do it . I only notice mine in the winter months . Rob
2000 Trans Am six speed Blackbird .Fast enough stock!
2005 Grand Prix.
2005 2500HD Silverado 4x4 , Duramax!!!!!!! Lifted ,Pumped,Humped,Thumped!
1988 JEEP Cherokee: Lifted, Sons new toy.
Old 04-04-2006, 10:12 PM
RG501 RG501 is offline
Send a message via AIM to RG501
i have that too on my 96 FireBird. it almost sounds like its comming from the exhaust. im thinking its piston slap though.
1996 v6 Pontiac Firebird
Old 04-04-2006, 10:26 PM
Mr. Luos's Avatar
Firebird Guy
Piston slap is an LS1 issue. Not an LT1 or V6 issue.
Stock'ish'
Old 04-05-2006, 02:11 AM
Rmbodie's Avatar
Not argueing with you Lous but there are 8 different engines from 3.1 to 8.1 that have the piston slap according to www.pistonslap.com. My wifes 3800 gen 3 has it . Rob
2005 Grand Prix.
Old 04-05-2006, 07:20 AM
Mr. Luos's Avatar
Firebird Guy
They can have it.
It was mostly an issue with the aluminum blocked vehicles though. Heat expansion issue basicly. Aluminum changes more under heat than iron.
Stock'ish'
Old 04-06-2006, 06:08 PM
2000LS1Z28 2000LS1Z28 is offline
You can have piston slap with any car.
GM goofed up and overbored the cylinder head walls, cause the pistons to slap.
I owned an LS1 with piston slap (My former 2000 Z28). It's very common amongst the 98-00 models, and less so with the 01-02's. In order to repair it they need to do a tear down of the engine. You're looking at well over $1K for repair. I was told that they'd take the block apart, acid drop it, put in new pistons (Non hypereutic pistons, cause they suck ass), and I thought he said sleeve the block. Not to sure though. I said screw it, and traded the car in.
If it is only the noise, i'd say screw it, as it isn't a real issue, after warming up. My former Z28 outright sounded like a diesel truck. I was told to use heavier synthetic oil 20W.
Hopefully it is just a bent pushrod.
2001 MR2 Spyder
Magnaflow Muffler and OBX CAI.
Old 04-06-2006, 08:10 PM
79Bandit's Avatar
ahh i didnt even think about that yea my trans am had that sound (something like piston slap sounds like) and when i tore down the block as yo ucan see from the pictures on my post labled *and it begins* there was a shattered rod and a bent one. that could very well be the problem if it just started happening
