Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-02-2006, 07:39 PM
rockbball929 rockbball929 is offline
bad gas mileage
hey i just had my turbo, manifold, alternator, and alt belt replaced. Well, my check engine light came on like a week or 2 ago and now, it seems to miss on the highway, does not take off nearly as fast, and i get about 90 miles to the tank, which turns out to be an awesome 6 miles to the gallon. i dont think it is a gas leak because i do not smell fuel. Please help if you can.
Thanks
Lance
92 talon tsi awd
all stock
auto
Old 04-02-2006, 08:41 PM
Killa's Avatar
Killa Killa is offline
Re: bad gas mileage
Do a basic tune up, like change spark plug, and wire, air filter, gas filter, change oil, balance yur tire ( and aligment ) and put enought air on it, put in a bottle of fulse inject cleaner, clean out the TB. and your car is auto turbo, it will eat alot gas then a manual turbo, dont let the rpm pass more then 2.5k, push the gas pedal slow. Good luck with the car.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 04-02-2006, 09:34 PM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
Re: bad gas mileage
it could be the o2 sensor
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
Old 04-02-2006, 09:41 PM
Killa's Avatar
Re: bad gas mileage
yea change that too.
GM FOR LIFE !!
95 camaro lt1
Old 04-02-2006, 10:01 PM
Re: bad gas mileage
where is tho o2 sensor at in the car
Old 04-02-2006, 10:03 PM
Re: bad gas mileage
and could that cause the mileage to be that bad?
Old 04-02-2006, 10:24 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: bad gas mileage
it's most likely a bad 02 sensor, it's located in the 02 housing right after your turbo (connects to downpipe) When this fails, the car doesn't know the a/f ratio at all so it just goes into "safe mode" and sends as much fuel as possible. 9-10 mpg is about right for a failed 02 sensor. It could also be a bad exhaust leak somewhere around the 02 housing, causing the 02 sensor to get a bad read on air.
now - 2000 civic
soon - 2002 is300
Old 04-02-2006, 10:52 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Re: bad gas mileage
"...6 miles to the gallon..."
Owned
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 04-03-2006, 06:37 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: bad gas mileage
Go to Autozone and have the codes pulled. Get a new O2 sensor while you're there too.
95 Talon TSI AWD
97 Eclipse GST
