Old 04-02-2006, 07:36 PM
X4gives X4gives is offline
2000 chevy blazer 2dr 4x4
latly ive noticed a squeaking coming from my belt, a guy tells me to spray some silicone spray on it, or WD40, so i went got some WD40 and spray the belt and the squeaking stopped, but after running for about 15 minutes, it came back alot louder. Than i used some silicone spray, and pretty much the same thing, though it did work a little longer.
my question is, is there anything better i can use, or would buying a new belt fix the problem.
i just got to about 90k miles. and when i accelrate, it gets louder.
thanx in advance for your help.
Old 04-02-2006, 07:55 PM
swalt's Avatar
swalt swalt is offline
Re: 2000 chevy blazer 2dr 4x4
Remove your belt, clean off your pulleys of the silicone spray and put on a new belt. I have found I don't get any more than 20,000k out of a GM belt before it starts to chirp/squeal. I have had better luck with the aftermarket belts (crosshatched design).
Old 04-03-2006, 05:14 AM
muddog321 muddog321 is offline
AF -Advisor
My guess would not be the belt but either the tensioner or idler pulley bearings are starting to go - common problem. Didn't say the mileage but alternator front bearings can also go but usually alittle grating or grinding with more of a chrip.
Old 04-03-2006, 09:14 AM
swalt's Avatar
He mentioned he has 90,000 on his truck. It is the belt. The noise would not disappear otherwise when he sprayed the belt with WD40. Not saying he doesn't have a tensioner problem with that mileage on it, but for what he described the belt is shot.
Old 04-03-2006, 12:46 PM
ok so i guess i should try first getting a new belt, seeing how that would probablly be the cheapest route. and swalt, u said the best ones are after market. im in chicago, il, we got autozones, would they have them, or where else might i find one.
Old 04-03-2006, 12:49 PM
billibong's Avatar
billibong billibong is offline
Autozone, O'Reillys, Advanced - any of those places will have serpentine belts to replace yours. Figure on about $35-40 or so for the new belt. THey're easy to replace, doesn't take more than 10 minutes.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 04-03-2006, 04:14 PM
swalt's Avatar
I'm using the Dayco PolyCog right now and I have no complaints with it. I found the GM belts seem to glaze up on the backside quite quick. I give my engine a good powerwash after each winter and detail it (not the belt), so that might be part of it, but I don't have the same problem with the Dayco.
