98 Metro Transmission question
I have a 98 Metro 3 cylinder with a bad 5 speed. What year transmission will fit. I was told that the older ones will not work. Thanks in advance.
Re: 98 Metro Transmission question
one way you can find out is to call the dealer parts department and ask them what transmission will work on the 98' if its a good dealer they should be able to tell you if that doesn't work you can overhaul it using a Haynes manual. good luck
I think you can use any 3 cyl trans from 89 to 2001. I have a 99 Metro that I put a trans from a 91. works fine and bolted right in.
Technically, any metro/swift/sprint/firefly trans will work from 89-01. Yours being a 98, you have 13" wheels. So you'll want to find a 95-00' trans from a 3cyl to get the proper speedo gear and final drive ratio.
