Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX > Technical
Technical Discuss Engine, Suspension, Drivetrain, and all other technical issues here.
Old 04-02-2006, 06:09 PM
David_NISMO David_NISMO is offline
s14 motor into 1990 S13
Any idea on how much wirng will need to be done to get a harness setup for an S14 into the single cam S13?
We have an RB25DET that came out of an S14 and before I start digging into wiring diagrams I thought I'd see if you guys had any thoughts on this.
Rolling in a power by a
Old 04-02-2006, 10:23 PM
D-Bo's Avatar
D-Bo D-Bo is offline
Re: s14 motor into 1990 S13
you should be able to figure that out.. its not hard..
look at the engine, find all the sensors and harnesses you need for the engine to simply WORK, then look for things like power steering, brakes, o2 sensors, headlights, windows, whatever. my advice is have someone make a harness for you and have a labelled diagram. thats what we did for my buddy's CA18DET swap.. worked out very well. but really, in the end all you need to do is find the sensors to get the car started and then work up from there. pick what bells and whistles you want and plug 'em in
add: electrical stuff doesn't matter when you're considering what car you're putting shit into. if the engine can fit, then the ecu can fit. and if the ecu can fit, wires can fit. the amount of wiring that will need to be done will solely depend on how much you want in the car
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 04-02-2006, 10:26 PM
sidewayzS13's Avatar
sidewayzS13 sidewayzS13 is offline
doin it sidewayz
Send a message via AIM to sidewayzS13
i need to go through all my shit and take out all of my un used wires and plugs to clean up my engine bay. and someday move the fuse fox to the backseats which will make the engine bay super clean d bo your post remined me thanx haha. if you google this im sure u can find a write up though where people have done it and do a step by step write up
Originally Posted by Muscletang
I say let it run its course. Most women experiment with things. They'll try something whether it's mind altering drugs, going down on their best friend, an Emo song, or plastic surgery.
Old 04-03-2006, 04:06 AM
I was hoping that someone would know if any of the s14 plugs with drop right into the SOHC S13 harness. I've already accomplished wiring an RB26 into my S13, so the RB25 will be a cinch compared to that. But I'm doing this swap on company time and will be trying to save this guy some money by finding the easiest way.
I'll do some searching next, thought I might get lucky and someone on here has already replaced their SOHC with an S14 motor or something.
Old 04-03-2006, 11:41 AM
doin it sidewayz
i think ive seen this done on zilvia
Old 04-03-2006, 06:25 PM
D-Bo's Avatar
wait. are you saying putting an s14 ka into an s13??
add: any engine that fits into an 89 240 will fit into a 93 240 and vice versa
Old 04-04-2006, 06:50 PM
No dude, we have an RB25DET that came out of an S14. I taking the angle of S14 wiring harness into s13 enginebay.
Rather than trying to reverse engineer what they did for the RB25 into the S14, then RB25 into S13, follow?
We'll be fine, just looking to see if anyone knew some shortcuts.
Old 04-04-2006, 09:50 PM
D-Bo's Avatar
oh ok, well then my suggestion is to have a generic harness made.. but thats obviously not the only option, neither is it necessarily the best
