Wire question
ok as you all know i have a 1990 gt, im going carb with it, want i dont know what wires i need and what wires i dont need for the Fuel, Air\fuel, Tech, oil, temp guages, the head lights, break lights, and i also was woundering if the power windows and lockes will still work. or if i should just wait till i get my new engine and turn every thing on, then just start cliping wires and when something stops working i know i need that wire, lol. thanks
Re: Wire question
Theres a thread about this in the carb/boost tech forum at TM.com. Check it out.
1969 Cougar 357w & TKO - 475hp |
Re: Wire question
i could not find that TM.com is that all it is thanks
Re: Wire question
turbomustangs.com
Re: Wire question
well it helped me out a little, this is going to be hard i guess
Re: Wire question
Its not as easy as I thought it would be. I have to do the same thing.
Re: Wire question
lol nice
Re: Wire question
Do you have a wiring diagram for your car? Look at one and identify what wires are in the engine compartment and what they do.
If you make an enlarged copy of the wiring diagram it will help make it easier to read and make notes on. Guessing is not the way to go. Having your circuits properly connected and fused is the way to go. When you are done, make a reference copy of the modifications. This will make it easier for you in the future if you need or want to change or repair something. |
Re: Wire question
I just bought a Painless kit for my car. Its for an old model T or something like that. All it runs is all lights, horn, and 1 extra which I will use for my cigarette lighter so I can plug the LM-1 into it.
Re: Wire question
how much was the painless wire thing and whats the item number, i was looking at those but had no idea witch one i would need, and was it hard or no.
Re: Wire question
Its was about $210 and its Painless p/n: 10308
Re: Wire question
sweet does it come with instructions, that is what i was looking for in the first place to tell you the truth, something as easy as that.
Re: Wire question
Before you buy, make a list of all the electrical devices you will need. (ie, lights, fans, radio, fuel pump, etc.)
There are places that will also make a custom harness for you for not too much more money. |
Re: Wire question
Well for my car all I need is headlights, tail lights, brake lights, turn signals, emergency flashers, reverse lights, running lights, dome light, horn, windsheild washers, and cigarette lighter. I am running an electric fan and fuel pump as well but they will be custom wired up seperate. I may put both on a toggle switch, not sure yet. I will have a hidden switch to kill the fuel pump though so that the car cant be stolen. Cant steal a car with no fuel pressure
. Also I have all Autometer guages that have their own lights so that will be easy to do as well. Just wire them into the headlight switch. When the headlights come of the dash lights will too.So I bought the 8 circuit modular (can mount fuse box anywhere I want) T-bucket harness that Painless recomended.
Re: Wire question
ok thanks alot.
