Old 04-02-2006, 05:00 PM
FemmeVamp FemmeVamp is offline
Question P0101 - Can Someone Help Me With This?
Hi...new here, I joined to find some help about my Blazer.I've been having trouble with it for about a week or so now. Doesn't seem like it has any power on steep hills and it jumps a lot so I had a friend of mine hook his machine up to it and he got the P0101 code - MAF or VAF A Circuit Range/Perf. I have no idea what this is or what it means....can someone plz help me and tell me what I need to do to fix the problem? Thanx!
Old 04-02-2006, 05:31 PM
gmtech79's Avatar
gmtech79 gmtech79 is offline
Re: P0101 - Can Someone Help Me With This?
It is a dtc for your mass air flow sensor. It could be the sensor itself, the wiring for it or the pcm, would need to diagnose it. Although in unusual cases I have seen plugged cats. cause a P0101 to set. The MAF is inline of you intake duct between the air filter and the throttle body.
Old 04-02-2006, 05:42 PM
blazee's Avatar
blazee blazee is offline
Problem?
A lot of times, simply cleaning it will restore it to proper working order. Disconnect it from the duct, you'll see the wires in the air way, spray them with some electronics cleaner. You can also use brake cleaner, but don't use carb cleaner, wd40 or any similiar products because they will leave a residue.
Old 04-02-2006, 05:50 PM
Ok, thanx...I'll try the cleaning 1st off and see if it helps...hopefully to fix it it's nothing that's gonna cost me an arm and a leg lol
Old 04-02-2006, 05:58 PM
blazee's Avatar
Problem?
As gmtech79 said, it's located in the air duct between the air filter and throttle body. Here's a picture: Good Luck.
Old 04-02-2006, 06:04 PM
Ok, so that's a pic of what the MAF looks like?
Old 04-02-2006, 06:11 PM
blazee's Avatar
Problem?
Yes, you can't see them in the pic, but behind that screen are the wires that I was talking about cleaning. You'll see them after you get it out and look inside.
Old 04-02-2006, 06:17 PM
Alright, gotcha, thx
Old 04-02-2006, 06:22 PM
blazee's Avatar
Problem?
You're welcome.
The wires are delicate so don't try rubbing them with anything, just spraying them will do.
Most of the time the cleaning will fix the problem, but if you need further help, just come back and ask.
Old 04-20-2006, 02:48 PM
thickheart28 thickheart28 is offline
THANK YOU SOOOOOO MUCH!!!! You saved me a TON of money and hassel! All I did was run out to checker, get electrical cleaner, clean that sensor inside of that housing, and it's good! My 01 Blazer is running SO smooth now, no hesitation like b4! I REGISTERED ON THIS SITE JUST TO SAY THANK YOU THANK YOU THANK YOU!!!! God Bless you guys!!!
Old 04-20-2006, 03:11 PM
blazee's Avatar
Problem?
You're welcome. I'm glad to hear that we could help you. It's always nice to get feedback.
