Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-02-2006, 03:56 PM
Mark1966 Mark1966 is offline
Unhappy leaks
I have a 99 dodge sport 4x4 I found alot of water in the driver side & pass.side floor board can anyone help this is a big problem
Old 04-02-2006, 11:01 PM
tony36 tony36 is offline
Send a message via MSN to tony36
Re: leaks
Have you had the windshield replaced lately?
Old 04-02-2006, 11:25 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: leaks
I sit inside and watch for leaks when it rains hard. That's the best way to find out where they're coming from.
Or get someone to shoot the truck with hose while you stay in and watch.
My Mopars
Old 04-03-2006, 12:50 AM
Re: leaks
If you only see water on the floor, chances are the windshield is leaking and running down behind the dash.
Old 04-03-2006, 03:49 PM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
Re: leaks
another thing to check is the drain for the AC. the tube is supposed to go through the fire wall, but ocasionally it will pop back inside the cab. and sense the AC cycles on and off when the defrost setting is selected, you can still get condensation even without having the AC turned on to blow cold air. also, even if the drain tube is still sticking through the fire wall like it's supposed to be, make sure that it isn't plugged, if it's plugged, the condensation will just pool in the blower housing, and leak out inside the cab.
but as mentioned above, sit in it wile it's raining, or have someone spray it with a hose to make sure that it's not the windshield that's leaking.
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
Old 04-05-2006, 05:16 PM
crazys182003's Avatar
crazys182003 crazys182003 is offline
Re: leaks
if that doesn't work I had my rear window leak water onto my floor. I could not see it but took it to my dealer and told them to find it. They ripped up the carpet and soaked everythign down and they found out it was my rear slider leaking. Aparently it is common for the sliders to leak. Also I have heard of the third brake light leaking and ending up inside the cab.
Old 04-05-2006, 07:56 PM
edbrycem edbrycem is offline
Re: leaks
what did they do to keep the rear slider from leaking? I just noticed mine the other day, god knows how long its been like that. its a 98 qdcab
Old 04-05-2006, 08:19 PM
BleedDodge's Avatar
Re: leaks
Put a one-piece window in.
My Mopars
Old 04-06-2006, 10:17 AM
Re: leaks
oh, thats sucks
Old 04-06-2006, 04:20 PM
Re: leaks
replace with a non factory rear slider. The problem with mine was when the tywo slide togetehr to close it wasn't sealing so they replaced the whole thing with a single rear slider. It took some getting used to having it slide only one way but it works and doesn't leak and was free to me b/c it leaked when I bought it.
Old 04-06-2006, 04:58 PM
Re: leaks
My rear slider leaks also but not through the sliding part it leaks through the seal along the top and only while driving. It has done so since it was new, I even had it replaced and it still does it, it has something to do with the design. I would have replaced it with an aftermarket window but they look like crap and the leak isn't bad enough to cause any damage.
Old 04-06-2006, 07:08 PM
Re: leaks
yeah i just noticed a couple drips running down the slider on the inside when i was on the highway. i never noticed it going through a car wash. i wonder why driving it makes a differnce
Old 04-06-2006, 08:42 PM
Re: leaks
well if its coming in near the top of the slider maybe its your third brake light leaking and appearing that its coming in the slider top. The easy way to check that is to pull the third brake light and silicon it when you put it back in. That seals it abck up and then if it stops leaking viola it might have not been the window. B/c if it is the brake light it would run down and then hit the slider then run inside and appear as though its the slider. If its the slider most likely it'll run in near the bottom.
Old 04-06-2006, 08:51 PM
Re: leaks
i'm gonna take the light out and silicone it for **its n' giggles and spray water right on it.....then i'll know what to silicone next. ha ha
Old 04-07-2006, 05:18 AM
Re: leaks
hey it may only take a few minutes and could fix your leak why not try it? But as always everyone does think wrong soemtimes.
