Cap and Rotor
Hi guys I have a question. I did a tune up on my 97 Bravada last fall. At the time it had 68K miles on it. I replaced the plugs, fuel line filter, PCV, and put in a K&N air filter and cleaned the MAF sensor.
My truck now has 75K and as of late I noticed it seems a little sluggish, not too bad but a little hesitant when accelerating. I am wondering if I should replace the cap and rotor? I did not replace that during the tune up. Is there something else that could be causing the sluggish response? I am currently getting about 19-20mpg on the highway and 15.5mpg in town. Thanks for any help as it is greatly appreciated. |
Re: Cap and Rotor
i would replace the cap, rotor, and plug wires. there are alot of things that could cause this. but this would be the most obvious of all. also check fuel pressure and check vaccum lines for leaks.
i dont know much about k&n filters but how often do they need cleaning? |
Re: Cap and Rotor
They need to be cleaned about 50k miles
Re: Cap and Rotor
Air Cleaners vary on how dusty is is where you drive, and a few other factors can be worked in as well.
I would start with the cap and router, plus pull and check your plugs. Most people on this board say that origional plugs are the only ones that'll work right. |
Re: Cap and Rotor
Thanks for the info guys. I appreciate it. I will be changing the cap and rotor very soon.
When I did my tune up I used Autolite platinun plugs from Autozone. They seem to be working fine so far. Are these a bad choice? |
Re: Cap and Rotor
Yes, indeed it was a bad choice. Take them back and ask for AC Delco Plats. The Autolites don't have the heat range our trucks need in a plug
Re: Cap and Rotor
Re: Cap and Rotor
No, our trucks do not respond well the Bosch plugs. They do not have the same heat range of the Delco's. We need plugs within a very high heat range, and Delco has been the best to provide that range.
Re: Cap and Rotor
ac is the best plug for the money. bosch and champion dont do well even if platinum or gold. dont forget to change your plug wires as well.
Re: Cap and Rotor
2004 Explorer XLT 4.0L 4x4 1998 Ranger Supercab 4x2 3.0L Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store! Come visit me on www.faceforums.com |
Re: Cap and Rotor
What are you referring to when you mean "heat range" ?
1999 Blazer 4x4 LS "Blackie" Monroe Reflex Shocks Moog U/L Ball Joints K&N FIPK Gen 2 Cold Air Intake Flo-pro Soundpro exhaust Optima Redtop 132k miles and still rolling.... |
Re: Cap and Rotor
Spark plugs have a specific heat range that they are specifically built to operate in. The other plugs do not stand up to this specification in our vehicles.
Re: Cap and Rotor
ac delco plats are gm replacement parts and are the best for our engines. yea they are a bit pricey but are worth it if u want long term realiability.
2000 Chevy Blazer ZR2 Performance Mods: Numerous Suspension Mods: Some, but not enough Exterior Mods: Just Right 1987 Buick Turbo T Dark Red Low 11 sec sleeper ![]() .030 4.1 block, PT6262E, & other odds and ends.... My Cardomain |
Re: Cap and Rotor
Hate to break it to you, but Autolite, 50% of AC Delco, and SplitFire are all made at the Honeywell plant in Fostoria, Ohio.
Not a lot of difference other than the brand and the number of 'ribs' on the ceramic insulator. |
Re: Cap and Rotor
ac delco.! lets take what booch said here in post number 14 for a second, yes they are made at the same plant, but, my buddie makes cheese, and at this same plant they make pepper jack, american, swiss and about a dozen other types, no 2 cheeses taste the same, no two plugs are created equil, you do what you want with your vehicals, but our blazers call for, work best, and last longest on ac delco platnum plugs, bottum line, every thing else is pure shit, including bosh 4, champion, autolite (ford plug) and any other redaly available plug... tommy boy says it best 'you can get a good look at a T bone by sticking your head up the bulls ass, but wouldnt you rather take the butchers word on it?'
