Old 04-02-2006, 10:47 AM
gardnerr06 gardnerr06 is offline
91 z24 blowing fuse
I've got a 91 cavalier z24 that keeps blowing the HVAC,heater and A/C fuse.As soon as I replace one,the new one is blown.Any ideas what might cause this?Thanks.
Old 04-02-2006, 04:26 PM
Re: 91 z24 blowing fuse
Oh yeah, The fuse is blowing as soon as I turn the ignition to the run position, before the car starts. Everything else is working fine.
Old 04-02-2006, 09:02 PM
jj76ta jj76ta is offline
Try to disconect the blower motor and then replace the fuse. if it blew then there is a dead short. If it doesn't blow after the motor is disconected then it is the motor.
Old 04-02-2006, 09:08 PM
vamc's Avatar
vamc vamc is offline
Look for ANY crimped wires by the ecu and other places.
Old 04-03-2006, 12:38 PM
Thanks, I will try that and look around at the wiring.
Old 04-03-2006, 07:51 PM
vamc's Avatar
Let us know what you find.
Old 04-04-2006, 07:31 AM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
if your heater/ac is turned OFF when you turn on the ignition, its not your blower motor. if that is the case its definetely a short, if its ever had an aftermarket stereo in it, i'd start behind the stereo
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 04-12-2006, 04:33 PM
Been looking and can't see any crimped or bald wires. How can I get the gear shift handle off? I,m trying to get a good look behind the heat/ac control panel, but the shifter handle is in the way.
Old 04-12-2006, 05:04 PM
Cavalier2000's Avatar
Cavalier2000 Cavalier2000 is offline
Banned
auto or stick
Old 04-13-2006, 05:03 PM
Auto, I found the pin in the front, looks like a big staple. I'm gonna look around this evening.
Old 04-14-2006, 09:07 AM
Banned
yea take it out and the pull up
Old 04-14-2006, 10:39 AM
Well, I looked around everywhere I could see. Unplugged all the wires from the control panel and hooked them all back up one at a time to see when the fuse would go, but it never did. Put everything back together and all is working fine again, ...for now.
Old 04-14-2006, 06:29 PM
and now i'm back to blown fuses. any suggestions?
Old 05-09-2006, 12:58 PM
could one of the switches be causing this, like the blower or a/c switch, or the ignition switch?
