Old 04-02-2006, 09:59 AM
E.Derrah E.Derrah is offline
1995 S-10 Blazer-Dome/Courtesy lights do not cut off
I have a 1995 S-10 Blazer. The Dome/Courtesy lights normally remain a short period of time after the doors are closed, then cut themselves off. My problem is that now they do not cut themselves off, they stay on all of the time (and get very hot). I have removed all of the bulbs until this can be corrected. Where is the timer/relay that controls this function and how is it replaced? Will this part be a dealer only item?
Thanks,
Eddie
Old 04-02-2006, 10:32 AM
goser goser is offline
Re: 1995 S-10 Blazer-Dome/Courtesy lights do not cut off
Don't have an answer for you, but on my 98 there is a dome override switch beneath the cabin dimmer--if you hit this in the dome lights won't come on unless you turn the dimmer full up...might be a workaround for you so you can still have light on occasion without screwing the bulbs back in...
Old 04-02-2006, 07:56 PM
VMI07 VMI07 is offline
Assuming that you have checks the obvious switches on the dome light and the dash controls check the rear tail gate lock. Does it function smootly. If it sticks it will cause the dome light to stay on and drain your battery. It could also cuase the door locks to hol din the unlock or lock position and again will drain the battery. If this is it GM can rebuild he assembly at the dealership for a few dollars
VMI07
Old 04-03-2006, 11:41 AM
frehol frehol is offline
Had same problem once on my -95 but it was just the instrumentation lighting dimmer that was turned to max, that turns the interion lights on.
If you have not tried it yet, just turn the dimmer down...
/Freddy
Old 04-09-2006, 06:23 PM
Jon Teeter Jon Teeter is offline
Check the pin that the door pushes in when its shut it may be stuck
Old 04-09-2006, 07:44 PM
muzzy1maniac's Avatar
muzzy1maniac muzzy1maniac is offline
This happened to me and it was the rear hatch glass the was poped open a bit.
2004 Explorer XLT
4.0L 4x4
1998 Ranger Supercab
4x2 3.0L
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
Come visit me on www.faceforums.com
Old 04-10-2006, 10:51 AM
JoulesWinfield's Avatar
JoulesWinfield JoulesWinfield is offline
Rear glass pin switch would be my first suspect. Also as mentioned the dimmer switch as well.
I would suspect those before the relay.
You can get schematics from onlinerepairmanuals.com. I bought one from him and foune it very helpful.
Old 04-10-2006, 02:42 PM
bigry2004 bigry2004 is offline
Send a message via AIM to bigry2004
i also had a similar problem and it was a faulty door pin.
1997 Blazer LT 204k miles, 4X4, BF Goodrich AT's, 2 Pioneer 6x9's, 12" IMPP subwoofer with 1000watt Pyramid Amp. CAI.
Old 09-18-2012, 04:55 AM
bam197658 bam197658 is offline
I found that if I kick with my left foot under the dash my lights finally go off I'll find out more in the morning it has to be a ground or connection in that area
Old 09-18-2012, 06:08 AM
Zombie thread!
Old 09-20-2012, 04:35 AM
Well no luck yet I'm going to have to rip it all apart and find
t... its some wher! And I'm still having problems with my shifting it doesn't seem to want or dow or down shift properly
Old 09-20-2012, 06:16 AM
Not sure what year your dealing with or if my issues were early production related, but i fount the large wire harness that is just left of the column was open and several wires were scraping against the main dash support.
the way the wiring was ran there is a lot of "potential" for problems.
Like earlier posts have said though, check the pin switch operation. Either the drivers door since its used the most or the rear passengers since its used the least.
Old 09-23-2012, 05:52 AM
Well still not finding the wire problem under the dash for the dome lights but I wired in a over ride switch. Now I'm throwing a code for knock sensor and my trany is not shifting normaly.. would the knock sensor do that?
