Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-02-2006, 09:21 AM
jet521 jet521 is offline
Tranfer Case Fill Plug
Hello all--Just Checking here to see if The Fill Plug on the NP 208 Tranfer Case might have a Reversed Thread Unlike the Drain Plug--I have tried the last 3 days getting the plug out using a 30 mm socket that fits loose--the 29 mm does not fit?--seems i need a 1 3/16 inch socket?--1 1/8 is to small and 1 1/4 is to big--I can't Imagine why this Plug is so Tight--I Tried Vise Grips--a 2 Foot long Cheater Bar and Air impact--Maybe a Hole Drilled in it with a Easy Out?? I am Afraid to use heat thinking I might hurt the Seals or warp the Case--any Ideals on the Solution other than a Total Grind Please
1986 W150 SE 318 2 bbl
Thanks jet
Old 04-02-2006, 10:34 AM
2000mudder's Avatar
2000mudder 2000mudder is offline
Re: Tranfer Case Fill Plug
my 91 w150 has a 241 transfer case but it should be the same. it was a odd size nut and it is right hand threads!!! mine was a bit stubborn too. not much on any car has a left hand thread!!!
Old 04-03-2006, 10:44 PM
sneakybert sneakybert is offline
Normal threads . The plug is exactly the same as the drain plug. A 30 mm six point socket and a good long 1/2 breaker bar is all I can recommend.
Old 04-12-2006, 06:06 PM
wafrederick wafrederick is offline
Banned
You need a 1 3/16 socket or 30mm,get a six piont socket.You can get that socket at certain auto parts stores or Sears(Craftstman brand) and the socket is really easy to find.A 1/2'' breaker bar is recomended to break it loose.The 1 3/16 wrench is a differant story,hard to find.
Old 04-14-2006, 09:47 AM
HEMIDAZE's Avatar
HEMIDAZE HEMIDAZE is offline
If you can't get it off, take it to an oil change place and let them do it. They don't charge extra for tough plugs (unless their price sheet says so). I had some shocks on my car that I could not get off and did not think anyone could get off. I took it to pep boys and let them worry about it.
Old 04-15-2006, 03:18 PM
Thanks all...I Did Take my Die Grinder to the Plug..Just Enough to Take some of the Pressure off the Flange of the Plug..LOL My my..all that time on one Lil ole silly Plug....But just wanted to Extend The Thanks to all who responded to my Post....Thank you all so Much
Jet
