2005 Dodge Caravan anti-theft reset- wont' start
Anti-theft alarm was triggered inadvertently and now won't allow vehicle to start. When ignition is turned there is just a click...does not turn over. Is there a reset???
Re: 2005 Dodge Caravan anti-theft reset- wont' start
I would check the owners manual for the security system and see if there is way to reset , the system currently is in a state where it thinks someone is trying to breakin thus it won't allow it to crank .
There isn't an active starter disable in those vans. It's passive, well, if you have the grey ignition key. Now, if you have an add on alarm you'll have to check that. Sometimes you have to press unlock 2 or 3 times to get the relay to latch back to let you start the car.
Silverado Ext. Cab 4x4 z71 Pioneer 4900mp Orion P6.2 Componet sets front Orion C63 Coax rear DirectedVideo 9" all in one DVD with surround 2007 SATURN OUTLOOK AWD XR with full entertainment package |
You reset the "anti-theft" alarm by inserting the ignition key in the outside driver door lock, turn the key to lock, then turn the key to unlock. That is the only way.
I learned this the hard way with a rental car. Thank God the owner's manual was in the glove compartment. The alarm will set whenever you lock the car either manually by lock button or power lock switch when a door is open and then you close the door; or by closing all doors and locking with a key in the driver door or using keyless remote lock button. Once the alarm is set, it expects the car to be unlocked either by keyless remote or a key from the outside. When the system begins to arm, you will see the "security" light illuminate on the dashboard during a 30 second time delay. Once the light goes out, the system will be armed. Once set, the alarm will go off if a door is opened or unlocked from the inside or the you attempt to start the car without first unlocking the car from the outside. I suggest you play with your alarm system so you know how it works and how to operate it. I once played a dirty trick on my father one day in his Ram 1500 pick up. As we are ready to leave to go somewhere, he opened the driver door and exited the truck to get something, leaving the driver door open. While seated in the truck, I pushed the power lock button and locked the doors. When he gets back in, he shuts the door and the security system starts it's time delay. Then he starts to play with this cell phone and then the system fully arms. He then puts the key in the ignition and trys the start the car. The alarm goes off and he sits there dumbfounded while I'm sitting in the passenger seat doubled over in laughter. That's the day he learned how his alarm system worked. Just last week, I rescued a poor fellow in this Mitsubishi Montero. He parked his car and sat in it a while, shuffling through papers in the front seat, or something like that. He opens his door and the alarm goes off. I watched him for about two minutes as he stuggles with things inside the car and looking dumbfounded. I then walked over to him and told him to use his ignition key in the door lock. The alarm stopped. I then explained to him exactly what he did to set off the alarm. And he confirmed that I was dead-on correct. He then thanked me for showing him what to do in the future. Good luck with this and let us know if you have any other questions.
"This car may be old, but it will still climb Kirker Pass at 110!" 1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible |
What year truck was that?
My father's truck is a 1998 Dodge Ram 1500 Sport.
someone tried to steel my 2005 dodge caravan. they peeled the column and popped the lock. can the security system be reset by using the key to reset it?
I doubt it. They probably ruined the system and that will need to be replaced.
