Old 04-02-2006, 09:01 AM
crow0021 crow0021 is offline
how much oil?
i'm doing a oil change on my 03 cav (2.2L ecotec) , how much oil does it hold? synthetic oil is ok to use? any tips for first oil change on this car...??
Old 04-02-2006, 09:24 AM
mhowe1182 mhowe1182 is offline
Re: how much oil?
you are going to need four qts of oil .and it pretty easy to do an oil change.
make sure to change the oik filter too.
1999 k1500 350 hd tranny
8 inch lift
35" tires
Old 04-02-2006, 09:38 AM
Cheetoe00 Cheetoe00 is offline
Re: how much oil?
2.2 ecotec takes 5.0qts. the filter is up top in the front of the engine. There is a i think a 23mm socket there, you need an extension to get to it. Also yes synethic oil is great for it. I am running Maxlife Syn in my car and it looks clean as hell. plus if you miss say 1000miles on the oil change you wont get sludge build up.
Old 04-02-2006, 12:29 PM
Re: how much oil?
with synthetic, it lasts alot longer but i still change my filter every 5000km??
Old 04-02-2006, 12:43 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: how much oil?
i know they make oil that lets you go 5000/7500 miles before changing, but im pretty sure youll need to change your regular synthetic oil just as often as regular oil
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 04-02-2006, 07:53 PM
Re: how much oil?
thx ... anybody know what i should torque my oil filter cover and oil drain plug to???
Old 04-03-2006, 02:54 AM
Re: how much oil?
hand tight. If you overtight it you can risk strippping it and thats no fun
Old 04-03-2006, 02:04 PM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
Re: how much oil?
Not to hijack your thread but can you reach the oil filter with just an extension? I found where mine is but i wouldnt be able to get it off from here. Is it easier to get it off from under or over it and where is the screw/nut it uses to hold on? Thanks
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
Old 04-04-2006, 08:33 PM
Re: how much oil?
well if you have a 96 cav it has a different engine then a ecotec. if you dont have that computer module in the way from the top you can use a band wrench to get the filter off. They started putting ecotec's in i think 1999.
