Old 07-10-2002, 07:24 PM
Skeme1's Avatar
Skeme1 Skeme1 is offline
can i change my alt myself?
with jacks and tools?
i need my car running asap
Old 07-10-2002, 07:26 PM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
you better change it yourself! otherwise you are not allow to own a 4g......j/k yeah its a real easy job.
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 07-10-2002, 07:29 PM
Skeme1's Avatar
how easy is it?
Old 07-10-2002, 07:34 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
You should just be able to remove or loosen one of the bolts, swing the alternator forward to relieve the tension on the belt, remove the belt, remove and unplug the alternator. Then, put the new one in, only tighten one bolt, put the belt on, then swing the alternator backwards to put tension on the belt, and tighten the bolt while pushing the alternator for tension.
Old 07-10-2002, 07:44 PM
Skeme1's Avatar
great!
thanks alot guys!
Old 07-10-2002, 08:25 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
its not that easy. its true that one of the bolts is for the tensioner but if you lossen the tensioner bolt you still cant swqing the alt because the other bolt still hold the alt in place. you need to lossen the bottom bolt and the top tensioner bolt, then you can swing it.
but if your replacing it then its different. first take of the connectors. then take off the tensionser bolt, the top bolt, and then lossen the bottom bolt and swing the alt and take off the belt. last, take off the bottom bolt and the alt should come out. installtion is reverse order.
first put the alt in place, then put the bottom bolt on but dont make it tight. then put on the tensioner bolt but dont make that tight teither. put the belt on, now here was kinda the tricky if you have to do ityourself. what i did was pryed a screw driver and pushed the alt so i could remove the slack in the belt, as i did that, i tighten the tensioner bolt, so now it wont swing and the belt doesnt have any slack. now i tighten the bottom bolt. make sure you torque everything down and put on the conectors again. tah dah your done
torque specs if you want to nknow:
1) tensioner bolt = 17lbs
2) the connector on alt = 5.79 lbs
3) the mounting bolt = 33 lbs
oh i should tell you that. i really did do this all myself but it was on a 92 civic with a b16. but i think it should be teh same.i too lazy to go out and look at my car
Old 07-11-2002, 10:29 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Alternator
Yeah, I've done this one a couple of times, and it's not too bad. The only trouble is getting your hands in there to work. Having a second pair of hands to help is a nice tool, even if it's just someone to say, push on this...
You can always hit autozone and grab a manual too, they come in handy!!
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 07-11-2002, 12:16 PM
Skeme1's Avatar
thanks for the help guys. im gonna work on it tommorrow
Old 07-11-2002, 12:42 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
you know what i did, that didn't require jacking up your car and not having to get under there...take out your brake booster...the alternator slipped right out when i unbolted the 2 bolts that held it on.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 07-11-2002, 03:46 PM
oh i forgot to mention to tape off teh alt connectors because if they touch metal then its gonna ground. so make sure your connectors dont touch anything metal
