Old 04-02-2006, 07:15 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Worked on my car today part 2
Hey guys, I got to tinker around on the Talon again yesterday and I found some more interesting shit. First off, I checked on the oil filter houseing and all the wiring down there is gank as hell, there was one thing not even connected so I wasnt too worried about the oil pressure gauge reading 0. Then I decided to go over to the belt side and just look at it from the bottom. There is a pulley pretty much directly underneath the intake manifold that didnt have a belt going to it! What pulley is that for? I couldnt find a damn pulley map or whatever in the haynes manual. I thought it might be the water pump and maybe thats why it was overheating, so I put the battery back in and compression tested it. From the t belt it was 135, 125, 125, 140. I'm thinking that maybe the head warped a bit when it overheated and those middle two got taken out a little. What do you guys think? I think I am still going to go through with the ARP head studs and metal HG just so that I dont have to do it later. After thats done, I will compression check it again and see whats up. Any thoughts on the hole missing belt/overheating issue? Also, when we were cranking it over to compression test it, oil was kinda squirting out of the turbo feed tube, thank god theres still oil pressure.
Also, we painted Mike's valve cover (the one we got from EDMUND65)yesterday. Today we will start polishing the letters.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 04-02-2006, 12:33 PM
MexRocket's Avatar
MexRocket MexRocket is offline
Re: Worked on my car today part 2
your getting your head resurfaced right? I bet you are, just making sure, a new HG and ARP head studs wont make a differance if it isn't resurfaced =). But I bet you are getting it resurfaced.
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 04-02-2006, 12:39 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
With compression numbers that low and distant, I would be thinking rebuild, not headgasket. The motor is too beat up, they're 15 apart which iirc is the limit.
now - 2000 civic
soon - 2002 is300
Old 04-02-2006, 12:43 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Directly under the intake manifold? You sure it's not the A/C compressor?
1991 GSX 2.3 Stroker
Old 04-02-2006, 06:19 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
get some pix
Old 04-02-2006, 10:00 PM
Thor06's Avatar
Jizzed In My Pants
Yeah, I think it is the AC pulley. Not sure what I was thinking when I thought it was the water pump .
So today I got the coil pack out and went for the intake manifold stay (thats what the haynes manual called it, the bracket deal). Between the firewall and the intake mani is NOT a good spot to be working! GOD DAMN it was frustrating! I fiddle fucked around for 2 hours on those TWO damn bolts. Finally used a pry bar to get enough leverage on the rachet on one and a long ass board and hammer to pound the other one around. Anyway we got it off, but my temper was short as hell after that...
Then we went to work on the timing belt. Well, tried. We were going at the drive belts and I couldnt figure out to get them to loosen and the Haynes manual was about as helpful as a Playboy is to a blind man. Can you guys tell me how to get them off?
I'm with you (crunchy) on the rebuild. I thought about it and I would have the head off anyway, why not just take the block with it? Remember the knock? Could still be rod knock, it would be a bitch to get the head gasket done and get it out on the road for a test drive just to have a rod go out the side of the block. Besides, after the rebuild it would take the mods so much better for so much longer before I need another rebuild. I have always wanted a stroker but damn, lotsa money. Also, if I did get a stroker, I would end up with a purpose built track car, not a mid/high 11 sec street monster like I want. Not sure, but I may try to see if I cant squeak out an 11 on the big 16g by boosting the shit out of it and using a little (lot) of nitrous . I'll get a 50 trim or something for that. Anyway, I am going to get the head off, then take the block out. I think I will just do a basically stock rebuild since I am aiming for 400 and not more than 450. I'm thinking I'll stay with the 1g big rods and go for some stock 2g pistons for the higher compression. What do you guys think?
Old 04-02-2006, 10:03 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
its the a/c compressor. 15 is the magic number but dont just to conclusions yet, I agree there is something wrong but it could be a few things. I highly doubt that you will need to touch your bottom end just because, yes you have readings 20psi apart, but it isn't likely for all the rings to fail at once. You will need to do a running and wet test just so you can verify where the leak is
EDIT: after reading your last post, if you already are having a rod knock you might as well tear that bitch down, I'd hate for you to have to do all that work and go beat the hell out of it and throw a rod
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 04-02-2006, 11:12 PM
Thor06's Avatar
Jizzed In My Pants
Yeah, the exhaust mani was hardly bolted on so I figured it was that, but theres still a chance of a rod knocking. Lets just think of it as preventative maintainance . If there is rod knock is there a chance the block, rod, and/or crank be ok?
1g rods with 2g pistons sound good?
Any insight on the fucking alternator and power steering (I think thats the other one) belts?
Old 04-03-2006, 03:09 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Whats wrong with those belts? That on missing belt is the a/c compressor belt, i don't see why people remove them, the compressor has a clutch so it doesn't really drag too much. A leak at the manifold will make a knocking sound, as aaron (he had like 2 studs actually in). I'd think the hg is bad especially considering the low compression is between two cylinders next to each other.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 04-03-2006, 05:04 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
If you think that you may have slight rod knock, pull off the rod caps and check out what the bearings look like, if they're scored or marked up then re-build the fucker. Otherwise I would just do a head-up re-build and call it good. If you ARE going to do a full re-build, 2g pistons on 1g rods will be just fine for what you're looking for. Good luck and post some damn pictures when you get to working on it.
95 Talon TSI AWD
97 Eclipse GST
Old 04-03-2006, 06:25 AM
blk_srt's Avatar
Originally Posted by gthompson97
The water pump drives off of the t-belt.
No it doesnt
Mods:
Old 04-03-2006, 06:30 AM
Originally Posted by pr_ricer
No it doesnt
My bad, I was thinking 420a. Maybe because I've replaced about 100000 water pumps on 420a's and none on the 4g63 (or yet anyways). Editing time so I don't look like a retard.
95 Talon TSI AWD
97 Eclipse GST
Old 04-03-2006, 06:32 AM
blk_srt's Avatar
I figured thats what you ment
Mods:
Old 04-03-2006, 08:03 AM
Thor06's Avatar
Jizzed In My Pants
I cant get those other belts off to get at the timing belt, I cant figure it out and the haynes manual didnt help me at all.
Old 04-03-2006, 08:09 AM
Just cut them, they probably need to be replaced anyways.
95 Talon TSI AWD
97 Eclipse GST
