Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 03-31-2006, 07:32 PM
IIwallabyII IIwallabyII is offline
crappy trans sport help
ok my 94 trans port wont charge itself or shift. it is just stuck in 3rd. motor runs fine and all that. also the power windows wont go down.
please help me out here, i need to know if any of these are related let me know
Old 04-02-2006, 07:22 AM
LMP's Avatar
LMP LMP is offline
Re: crappy trans sport help
I suppose your transport is a 3800 with 4T60 transmission.Third gear is the default condition for this transmission when both A and B solenoids are deenergized. So as a first step check "TCC/A/Bsol" connector for corrosion or being accidentally disconnected (?!?) .
www.avigex.ca/xport/tccplug.jpg shown here disconnected.
Power window failure is often caused by faulty switch on driver side. Both +12v and ground are routed through the switch. ALso broken wire at the door-frame interface has been reported . I would also check the pwrwindow breaker in convenience center (you can interchange with one other for a test)
www.avigex.ca/xport/convenience_center.jpg
www.avigex.ca/xport/pwrwindows.jpg
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
