Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-31-2006, 07:25 PM
rebel115 rebel115 is offline
92 Ford Ranger
I own a 92 ford ranger, and every day when you first start it for the first time in the day or if you leave it sitting for a long while and start it up it will start idle very poorly and then die!! So you have to start it back up and keep giving it gas for it to stay running. I recently changed the rotor cap and the spark plugs and it still runs poorly!! Is there anybody who can help me or have any suggestions?!?
Thanks
Alex
Old 04-02-2006, 06:29 AM
KimMG KimMG is offline
AF - Advisor
Re: 92 Ford Ranger
What did the spark plugs look like? Are you running lean or rich? How's the cold start valve?
Old 04-02-2006, 10:19 AM
2000mudder's Avatar
2000mudder 2000mudder is offline
Re: 92 Ford Ranger
many things to check. coolant temp sensor controls fast idle.i'd start there first $10 part. throttle position sensor,MAP/ BARO sensor, air temp sensor? lots of things to try.
Old 04-02-2006, 10:54 AM
Re: 92 Ford Ranger
Thanks guys I figured out where the cold start valve was and replaced that and it seems to be working fine now. THANKS AGAIN
Alex
Old 04-11-2006, 08:27 AM
brypkirk brypkirk is offline
Re: 92 Ford Ranger
replaced fuel pump and fuel pump relay, checked reset switch not acctivated.Fuel Pump still doesnt come on when keyed. what else could i look for?
Old 04-11-2006, 10:26 AM
2000mudder's Avatar
Re: 92 Ford Ranger
you didn't say if you checked the fuel pump fuse? thought it was running good after cold start valve repair? check for voltage at fuel pump wires.
Old 04-11-2006, 10:43 AM
stuzman stuzman is offline
Re: 92 Ford Ranger
It looks like a different poster from the original. As mudder said, check to see if you got any voltage to the relay contacts and if the relay is being pulled in.
