Go Back   Automotive Forums Car Chat > Ford > Contour
Old 03-31-2006, 07:10 PM
cherylobi cherylobi is offline
2000 Contour
Looking for an under the hood diagram fro 2000 contour. Car has coolant leak from a part to the right of the valve cover. Is it the water pump or thermostat?
Old 04-02-2006, 06:24 AM
KimMG KimMG is offline
AF - Advisor
Re: 2000 Contour
Can you post a picture?
Water pump has a belt going to it, the thermostat doesn't.
Try autozone.com to see if they have a free repair guide for your car, otherwise try the library if you don't want to buy a repair manual.
Old 04-02-2006, 10:04 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: 2000 Contour
if its the V6, both the thermostat and the w/p are located to the right of the valve cover.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
