Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 03-31-2006, 06:07 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
New headlights
My brother has a 03 eclipse GT and he bought some new hailo projector headlights for his car and i put them in but there is that wire that just plugs in but then there is another two wires, they are black and white. The headlights work but i was wondering what do they go to or do? The lights don't look as blue as they should, do they power blue lights or something?
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 03-31-2006, 07:10 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: New headlights
those other wires are for the Halo's. Wire them to your parking lights. The lights probably dont look as blue as they did in the original picture because they probably photo shopped it to look better. Buy some different bulbs, or better yet convert to true HID. There is plenty of info on this forum to help you with that. If youve got some other questions about wireing in the HALO's drop me a line.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 03-31-2006, 07:24 PM
97cavalier's Avatar
Re: New headlights
so just splice the wires to the parking lights?
Old 04-02-2006, 11:48 AM
97cavalier's Avatar
Re: New headlights
ok so on the drivers side there is three wires on the parking lights a green a pink and black. i know the black was ground so i wired that to the halo ground and the pink was positive so i wired that. But on the pasenger side parking light there was two green and one black. So i know black was ground but i did not know which one was positive. so i just gesed and spliced the one green and put it all to gether and they halo's worked when the parking lights were on and all the blinkers worked but when i turned the parking lights on the dash mph lights would not come on but they flashed when i turned the right blinker on. I need help fast because i have to get this car fixed today, so if any one knows any thing about this PLEASE let me know. Thanx alot.
Old 04-02-2006, 01:24 PM
rodbls's Avatar
Re: New headlights
well, if they flahsed when you turned your right blinker on, then it must be that you wired your right HALO into your turn signal instead of your parkin light wire. Easy mistake, and hopefully and easy fix. Just change the wire to the other green one, and hopefully that will fix it.
Old 04-03-2006, 07:47 AM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: New headlights
don't you just love mitsu? they put one color wires on one side of the car, and different color wires on the other side. somebody must have been smoking crack that day.
Old 04-03-2006, 07:37 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: New headlights
someone was passing crack down the line as mine was being made...
Don't act like you don't love it.
503/2000
Old 04-03-2006, 09:52 PM
97cavalier's Avatar
Re: New headlights
lol ya that is messed up how the wires are diffrent, but it turned out that i had to wire it into the other green one since the one it WAS in was the turn signal, and i had a blown fuse also. but now they are all hooked up and look real good!! thanx alot for all your guys help!!
