Old 03-31-2006, 05:09 PM
mikethehammer's Avatar
mikethehammer mikethehammer is offline
Bad News........
It is so fucking windy today, i was changing my oil and the wind got ahold of me and i spilled used oil all over my dads driveway. what a mess
Anyone know of any solutions to get used oil off of a concrete driveway????
Old 03-31-2006, 05:35 PM
2000CAYukon 2000CAYukon is offline
Re: Bad News........
Cat litter to get as much of it up as possible using a broom to move the litter around.
After that I would use a degreaser and stiff brush, rinse with water. Repeat as necessary with the degreaser.
//2000CAYukon
Old 03-31-2006, 06:19 PM
Elbert Elbert is offline
yea...they also make a product "oil dry" thats like cat litter..... might also look for some concerete cleaner. I know saftey clean use to make some good stuff (kind of yellow granular stuff) don't know if you can get that at your lcoal car parts place or not.
Old 03-31-2006, 06:23 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Pressure washing the driveway will get the vast majority of it up
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 04-02-2006, 10:21 AM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
I think my I've seen my dad use laundry detergent. But I would use a pressure washer.
*Under Construction - New sig to debut*
Old 04-03-2006, 10:00 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
I like Greased Lightning.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 04-03-2006, 11:03 AM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
After getting the surface oil up with kitty litter, get some powdered tide use quite a bit, get it wet but not enough to wash it away then with a stiff brush scrub, may need to repeat. If you have access to a steam cleaner try that first, it will not require as much elbow grease and, it will work better than a preasure washer.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
Old 04-03-2006, 05:27 PM
thanks for all the info but i don't think he noticed. i will wait till he goes out of town to try to clean it
Old 04-03-2006, 07:33 PM
06Z71 06Z71 is offline
Try Muriatic acid but be careful it will bleach ur cement,kill grass,eat the rubber of your tires and kill small animals. SO BE CAREFUL. But it works great
Cranked Bars
Silverstar headlight + 8 Light Mod
TrueFlow Intake + Airaid TBS
5% Window Tint + 30% On Front Windshield
Billet Grill + Bugshield + Ventvisors
And Still Spending
Old 04-04-2006, 01:46 AM
skipr skipr is offline
Yes this works very good, almost too good. May turn oil spot into clean white spot, then you can do the whole drive way to match. Pool acid I think is muratic type. Don't use sulfuric or worse hydrochloric.
Old 04-04-2006, 08:22 AM
HanibalTheCannibal's Avatar
HanibalTheCannibal HanibalTheCannibal is offline
If my son said "Dad I changed my own oil and the iwnd made me cause a mess" I would be proud of him, provided he tried to clean it, which you are.
Simple green mixed with bleach (use outdoors only) will remove it. I have a 77 ford f150 daily leaker and I live in a leased house, you bet I tried everything. Untill I found a magic formula. I mixed it in a deck sprayer (or a pump up bug sprayer thing) and use it for spot cleaning. Make sure you have fresh air, its pretty harsh stuff but works great!!
Good Luck!!
2001 5.3 LS Stock
6 channel Alpine 3566 Amp
Jason Extreme Slam Camper Shell
Michellin X-Radials
79K Miles
