Old 03-31-2006, 03:43 PM
stone_mound_camaro's Avatar
stone_mound_camaro stone_mound_camaro is offline
Could it be? and.... How much?
ok... so ive narrowed down the problems with my car to not being the ignition system, anthing with the engine or trannny. I think it might be a fuel pump failure. Is this a common problem with miles>120k? because i think i had the same problem with my last maro. The fuel pump itself is about $150ish. How much SHOULD labor be to put it in?
car audio guru...
Old 03-31-2006, 07:18 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Re: Could it be? and.... How much?
Do it yourself and it wont be much more than that..
Old 03-31-2006, 07:20 PM
i would, but i lack the necessary things: you know the usual... a ramp, tools, time....skill
car audio guru...
Old 03-31-2006, 08:19 PM
stepho stepho is offline
Send a message via AIM to stepho Send a message via Yahoo to stepho
the fuel pump is a very common problem for chevrolets. I must have changed twenty of them.
Chevrolet for some strange reason also likes to put the electric fuel pump inside a box of a highly volitile explosive liquid.
aside from that being a crazy idea... it also is a pain in the ass because the exhaust which is under the tank will have to be dropped. Also the fuel filter neck is somehow bent into place after its in the car so its going to be hard to get out.
Changing fuel pumps is a rediculous experience. Also on the newer camaros the stupid fuel pump has a yellow peice of plastic around it... and they charge twice as much for it.
Originally Posted by sportlinetta
lol, u guys are dummmmmmmmmmmmb im 14 n i know more. i gotta 88 camaro.
would that mean get a new cylinder or plug???
Old 04-02-2006, 07:18 AM
Dick Wolf Dick Wolf is offline
Banned
cut a whole in the back.
Old 04-02-2006, 09:47 PM
bag91's Avatar
bag91 bag91 is offline
that sucks!!!!
91 RS Camaro V8 305 TBI
cold/ram 14"/3" open element
K/N filter
3.73's
B&M Megashifter
180 thermostat
Flowtech TERMINATOR Exhaust
3" exhaust cutout
Silvania Silverstar Headlights
Ronal R15 Firehawk Wheels
Hankook Ventus Sport (front)
Sumitomo HTR+ (rear)
275/40ZR 17 all around...
_____________________________
Old 04-02-2006, 10:07 PM
Is eating.
Funny because I borrowed a ramp from my neighbor.. tools, I had, and skill? I just dove in.. and yes it is a bitch like KPot said.. in retrospect it is way easier to cut a hole in the back..
Old 04-02-2006, 10:10 PM
bag91's Avatar
how much time?
K/N filter
3.73's
B&M Megashifter
180 thermostat
3" exhaust cutout
Old 04-02-2006, 10:33 PM
Is eating.
Total time? like 5-8 hours, but that was only because I worked on it a bit, then went inside and continued on it about an hour later.. actual working time around 3-4 hours, the actual hard part is taking the pump out of the tank, its a real pain.
Old 04-03-2006, 02:19 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Have you verifed the system pressure yet? That'd really be a kick in the nuts to spend a good day drop'n a fuel tank for nothing.
Oh, and it' the vapor that's volitle, not the gasoline it'self.
Old 04-03-2006, 05:00 PM
No, but ive done massive research on the problem, symptoms, and narrowed down the possibilities to this... the fuel pump. theres no way it could be anything else. everything else has just been finely tuned.
car audio guru...
Old 04-03-2006, 05:13 PM
I have to disagree. Getting the pump out is the easiest part because you actually have room to work considering the tank is now removed from the car. The hardest part is probably getting the tank to drop out of the car. I've done it twice and both times the fuel filler neck had to literally be bent to get the tank out of the car.
EDIT: Also why did they put the pump inside the tank? Seems like it would make more sense to have a remote pump.
Old 04-03-2006, 05:34 PM
Is eating.
Stepho, good point. It is a real pain to drop it, and since I didnt bend my fuel filler neck, thats why I said getting the pump out is the bigger pain. But yeah it changes depending on which way you go at it.
Old 04-03-2006, 07:01 PM
Jcrane88 Jcrane88 is offline
Send a message via AIM to Jcrane88
oh man....i wish you luck. it was much easier when they mounted the pump on the side of the engine block....in my car i have my fuel pump under neath the rear seat....several months ago the fuel pump in my moms van went out..besides it being in the tank...you dont just change the pump...you change everything sender, pump etc. they want an arm and a leg for it....changed it in the mcdonalds parking lot, in a Illinois winter while it was raining.........
1984 Camaro 5.7L 350
700R4
Holley 650 Cfm
Edelbrock Performer Intake-Manifold
Crane Cams Duration @ .050": 204/214 Lift:420/442
Summit HEI Distributor
Hedman Shorty Headers
Hedman Y-pipe
Dynomax Turbo cat-back
NOS Decal
VTEC Decal
Old 04-03-2006, 07:20 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
You don't need ramps to change a pump cause you need to have the vehicles weight supported by the chasis and the wheels need to be lowered which is not possible with ramps. I did mine but with suspension components that were not touched from the look of it since the vehicle was built. They gave me a bitch of a time coming out and had to cut and hammer a few nuts and bolts out. I would say its not too bad of a job if you don't run into any snags though. Also I agree. gasoline in liquid form is not that dangerous, its the vapor that will cause a issue. Also don't get a stock replacement pump. Get a aftermarket one. They will probably last longer and allow more room for modifaction.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
