Old 03-31-2006, 01:41 PM
Optech Optech is offline
Metro Run on
I just bought a 95 Metro 5spd it has 105000 miles on it. There is a egg smell from the exhaust and the flange connecting the exhaust pipe to catalytic is leaking. The car has 150 psi compression on all four cylinders. I put new plugs, cap, wires. It is hard to start cold or hot but will start. The firing order has been checked, I have not dug into adjusting valves yet. The car will run on when I shut it off. Could this be a fuel related problem it has what appears like a throttle body. Or is it emmmission related. When it idles it sounds like it has a miss. There is spark going to all cylinders. I check for a manifold leak by squirting wd40 around the manifiold, no change in rpm. No codes on computer. Any help is appreciated.
Old 04-02-2006, 08:20 AM
seb001 seb001 is offline
Re: Metro Run on
About 15 years ago I had a Nissan Sentra that run on. Once the engine was hot it did not run very well. I checked everything, changed a bunch of stuff...
After two week, I took it to the mechanics. Took him 5 minutes to tell me that the main engine fuse had blown. Took 1 minute to replace. Never blew again.
A blown fuse prevents fuel cut off valve from activating.
Worth a check (Check all fuses)
Seb
Old 04-02-2006, 09:17 PM
coopdavillage's Avatar
coopdavillage coopdavillage is offline
Re: Metro Run on
you can also check the timing ive had it do that before but it could be a lot of carbon build up on the pistons but a cleaner should help with that. also check your thermostat if its faulty it will cause it to diesel. good luck
